3/16 Square Motor Couplers
  • RaceMechaniX
    • 3024
    Looks great Mark!
    A little on the tight side of the cable is OK, it's pretty easy to file down a fat cable. A half thou over on the diameter should also work just fine unless a particular shaft is close to the lower tolerance. What alloy brass are you using?
    Tyler
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • mm123521
      • 193
      Tyler:
      It's just 360 brass.
      I think it would be too difficult to use steel or a harder alloy of brass - it took substantial force to push the broaches.
      360 is easy to cut, but it may wear out too fast?
      Mark
      Avatar is the dangerous end of a Gatling Gun!
      • RaceMechaniX
        • 3024
        Mark,
        360 brass will hold up pretty good, an alternative to using 303 Stainless would be to use a 6061 or 7075 and hard anodize it. For the brass I would be more woried about the set-screws stripping than the square wearing out.
        Tyler
        Tyler Garrard
