Connector suggestions?
  • ManuelW
    • Oct 2010
    • 743
    Hello Guys,
    well as said it would be to much effort for a private user to make these measurements and care about it. But I think for the OSE shop it would be rentable to have all their connectors checked and post the results as well as take the best ones in the shop.
    For example would be interesting to see how the various 8mm systems compare to the 6mm LMT system? And for size, with 4.1g the LMT is a bit above 1/3 of the size of the 8mm system - I think that difference can matter.
    Best regards,
    Manuel
    • Flying Scotsman
      Fast Electric Adict!
      • Jun 2007
      • 5190
      I just wish that some company came up with a bullet designed Deans type connector.
      Douggie
      • Rumdog
        • 6453
        Douggie, the EC5 connector from Hobbyking, bud. I pesonally haven't tried them, but guys here who use them like em.
        • Flying Scotsman
          • Jun 2007
          • 5190
          Thanks Ryan, I will check them out.
          Edit: checked them out, does the plastic housing take high heat, a pity they were not 5.5mm or higher...I will try them out.
          Douggie
          • JimClark
            • 5902
            They are supposed to be good for 120 amps continuous
            Billy Graham
            • domp444
              • Jul 2009
              • 846
              These connectors seem pretty good: http://shop.rc-electronic.com/e-vend...t=12&c=44&p=44
              Just found them while browsing Emcotec stuff. Resistance is <0,04mOhm, that's even better than the LMT ones!
              • domp444
                • Jul 2009
                • 846
                But they say they will handle 120A max, and the LMT say 200A. I don't know, what do you guys think about them? Also, the Emcotec ones are 8mm, and the LMT ones are 6mm.
                • sundog
                  Platinum Card Member
                  • Feb 2009
                  • 878
                  The reason for the lower amp rating is the thin (slotted) metal that is making actual contact - conducting the current. And they would also be harder to solder without inspection holes in them to allow good flow. I'd stay away from these.
                  • domp444
                    • Jul 2009
                    • 846
                    Oh alright, I see. LMT is closed until the 7th, I'm thinking of going with their 6mm plug system. If not I'll go with the OSE 8mm plugs.
                    • ManuelW
                      • Oct 2010
                      • 743
                      Hello Guys,
                      I just took a look at the Emcotec 8mm system, the resistance of 0.04 sounds great but then why they rate it at only 120A? Because the resistance defines how good it can "handle" the current. Anyway, at 7.90€ a pair they are really expensive.
                      @ Domp444: Would be curious to see your experience with the 6mm LMT System. I think you'd be surprised of the outstanding insertion force.
                      Best regards,
                      Manuel
                      • domp444
                        • Jul 2009
                        • 846
                        Yeah, they're expensive and only rated to 120A. I'm waiting for a reply from LMT since I think I'm gonna go with their connectors. They seem to be of highest quality and current rating :)
                        • domp444
                          • Jul 2009
                          • 846
                          Well, guess what finally came today!
                          My LMT plugs. I will be using these for the lipos for my DOI.
                          • ManuelW
                            • Oct 2010
                            • 743
                            Hey,
                            have you already tried to connect and then disconnect them? I really hope you are satiesfied as they were my recommendation and are quite expensive as well.
                            Best regards,
                            Manuel
                            • domp444
                              • Jul 2009
                              • 846
                              I did try to connect them, but it is quite difficult to do it when they are not soldered on to anything. I think tomorrow I will put them on my lipos and try them out. They are thick and look very strong. I think they will be worth the price.
                              Thanks for the recommendation Manuel!
