Any thoughts on how this happened?
  • britscoot
    • 721
    Genesis cat
    150 cable well greased
    leopard 2000kv
    Grim 40x53 prop
    4s lipos
    Ran really well for 2 runs.
  • britscoot
    • 721
    Both parts still spin freely.
    • m4a1usr
      Fast Electric Addict
      • 2036
      Since that appears to have happened outside the hull, under water, and it occurred due to the flex binding, a bit more detail of your driveline is required.
      John
      Change is the one Constant
      • britscoot
        • 721
        i dont really know what more i could explain.
        Fairly new 150 cable with a 3/16 shaft well greased.
        no Teflon liner.
        Brass bush in the strut.
        No damage to any other part of the boat.
        let me know if you need more specifics.
        Thanks!!
        • carlcisneros
          • Jan 2010
          • 1237
          possibly caused in part due to the drive dog not having enough free space between the strut and the drive dog itself. (need about 1-2mm for cable tightening.)
          IF you look very close at the bottom portion of the cable, you will see the internal portion of the cable that is supposed to be inside the upper portion of the broken cable.
          Again, this is a possibility.
          Carl
          • m4a1usr
            • 2036
            Thats fair enough. Did the water contain organics like branches, leaves, water lilies, etc? If something got wrapped around the prop the load could be huge. Were you running a large gap between the motor coupler and the stuffing tube? Makes a difference. No liner doesnt mean a thing. Did you have a large gap between the drive dog and the strut? I've seen this same thing happen before but usually between the coupler and the stuffing tube inside the hull where the flex shaft was unsupported.
            John
            • domwilson
              • 4412
              Was there anything between the two tubes? Like heatshrink?
              Government Moto:
              • domwilson
                • 4412
                The reason I ask is there appears to be no grease at the point of damage.
                Government Moto:
                • blackcat26
                  High Speed Junkie
                  • Sep 2009
                  • 1750
                  Looks like there was too much unsupported length between the strut nose and the stuffing tube. Look at both ends, they are wallowed out. Prolly looked like a jump rope before it gave out...
                  • Alexgar
                    • Aug 2009
                    • 3701
                    ive had this happen with to much slack under load the pressure forced against the shaft caused tit to twist
                    • Alexgar
                      • Aug 2009
                      • 3701
                      i was posting as bj26 posted the same i agree
                      • keithbradley
                        • 3671
                        Cable whip,.... that would be my guess as well.
                        www.keithbradleyboats.com
                        • Diegoboy
                          • Mar 2007
                          • 7444
                          • graill
                            • 407
                            "prolly looked like a jump rope before it gave out"
                            I would go with that too. I did a piece a while back on flex shafts and them orbiting on themselves and their carrier at rpm. Its buried somewhere in here or RRR.
                            • domwilson
                              • 4412
                              That would explain the flairs on both tube ends.
                              Government Moto:
