M1 Supercat 1st run/not
  • Flying Scotsman
    Fast Electric Adict!
    • 5195
    Well, wee Douggie set off to the local pond full of expectation to run his MI
    All went well until I tried to arm the ESC (Sentilon OERC 100HV). No luck, I then re-programmed ..success.
    I was still wary..disconnected power .. same thing...hmmm.
    Rather than risk a new boat or a duck's life, I went home.
    I found the problem, this Sentilon requires a PIStix. The point is, all seemed normal and I have another OERC 100HV that does not require a PIStix. So be aware if your ESC arms after programming but does not arm normally after removing power, you may have an ESC that will glitch
