Micro mono torque roll
  • martin
    • 2881
    Ive got a micro mono deep v thats pretty fast on a x435 but do get some torque roll if the waters not flat, Would going to a 3 blade prop help in this area whilst still maintaining the speeds. If i run a 30 mm & 32mm it reduces problem at the expense of speed. Would trim tabs also help. The hull is on the edge for its size & speeds that its doing. Martin.
  • sailr
    • 7128
    typical mono when it approaches its 'hull speed'. Trim tabs may help. 3-blade prop would probably produce MORE torque. If you went down to a 32mm 3 blade, it would probably just cavitate.
    Mini Cat Racing USA
    www.minicatracingusa.com
