Genesis twin 6xl setup
  • RFOUNTAINIII
    • Dec 2010
    • 9
    I RECENTLY PURCHASED A GENESIS TWIN WITH 3674 2770kv 6xl motors! LOOKING FOR ADVICE ON ESC AND LIPOS TO USE! THINKING 120 OR 180 ESC AND SOME 6S 5000MAH 40C LIPOS! ANY ADVICE ON SETUP AND WHAT TO USE WOULD BE GREATLY APPREACIATED!
  • Brushless01
    • Apr 2010
    • 489
    Id run 3s per motor !!
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
      • 7512
      Was that the E-Bay Genesis........6S on a 6xl motor= if that what the original owner was running, I suspect the motors could be stressed and not have much life left in them.
      • RFOUNTAINIII
        • Dec 2010
        • 9
        I am shootn for 70 plus and 3s wont get me there i dont think!
          • 7512
          Are you looking just to do SAW running (one or two passes over a few seconds each) or trying to get some decent run time as well?
          • RFOUNTAINIII
            • Dec 2010
            • 9
            I want to do both! I have some 4s witch i wanted to do most running with, hopefully high 50 to low 60! And then the 6s for saw runs hopefully touch 70! What r thoughts? Should i remove the motors and run something different?
            • b.mcdaniel.2009
              • 1872
              Twin 10xl's or two Leopard 4082 1500kv on 5-6s each should do the trick. Just FYI, the Genesis doesn't like anything over 65mph, around 70mph they take flight, how do i know,..... It happened to me with a single Castle 1717, T-180 on 6s and a x 645 prop.
              ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
              • keithbradley
                • 3671
                Here ya go...this guy has some awesome setups, and is using affordable components!:
                I would copy him. I havent seen it done better yet.
                www.keithbradleyboats.com
                  • 9481
                  I can do 60mph on 4s in my Revo
                  but running more than 4s on those motors in a boat, could be asking for smoke
                  and I would think SAW only?
                  • Dangerous_Toys
                    Hiding from the Ole Lady!
                    • Apr 2010
                    • 2539
                    If my calcs are right, 6s on those motors is 61494 rpm's. Those motors will . I would have to agree with Brad and go with the 10XL or the Leopards. JMO
                    ? WHAT RULES?
                    • Rumdog
                      • 6667
                      lol.
                      • RFOUNTAINIII
                        • Dec 2010
                        • 9
                        I want to get some run time on it before i start upgradeing! From what im hearing 6s is out of the question! Do i need to stick to 4s or would i be ok with 5s?
                          • 7512
                          4S will be pushing 40,000 RPM.......those are really 3S Motors.
                            • 9481
                            Start with 3s
                            • LarrysDrifter
                              Big Booty Daddy
                              • May 2010
                              • 3416
                              Are you the Legendary Reggie Fountains grandson?If so,thats awesome!!!!!!!!!!!!!!!!!!!!!!
