Just bought a Apparition twin from the SS and need some help choosing motors. I did a search have found most folks running the Feiago 380xl's on these hulls and the ekos hulls, but I don't want to go that route. I do have a question though will a 540 36mm can fit? I know Bill O upgraded his EKOS to 540 cans by just modding the motor mounts, just curious if anyone has tried it with the apparition hulls. I know the ekos hull is a little bigger though. I will be replacing the 4mm bushings on the strut with some 3/16 aeromarine bushings and I will use .150 3/16 flex cables that I already have (the cw mg cable and the replacement ccw mg cable).
A) Leopard 2860 2730kv on 3s
B) Leopard 3650 2930kv on 3s
C) Ammo 3650 2300kv on 4s
C Ammo 3656 2600kv on 3s/4s
D) Ammo 2845 2700kv on 3s
Esc's would be twin seaking 120s.
Another question is should I run isolate each esc and battery or should I parallel the esc's and parallel the batteries on 3s and if I ran a 4s set up should I parallel the esc's and run 2 2s batts in series or parallel the esc's and run 2 4s batts paralleled?
