Assembling MHZ Scale Drive
  • domp444
    • Jul 2009
    • 846
    I got my Mystic hull and hardware in, and I'm wondering about the drive assembly.
    These are the ones I have: http://www.mhzusa.com/Scale-Drive-fo...?categoryId=-1
    It says that it accepts a 2mm wire drive. I've never done anything with wire drive, so I'm wondering how this works
  • westbeach
    OSE Rocks!
    • 951
    For the motor, you will need a collet sized to fit your motor shaft with a 2mm end for the wire. The wire is simply glued in with loctite 648 as stated in the description.
    HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
    • domp444
      • Jul 2009
      • 846
      Is that it? I wanna make sure I don't miss anything.
      Would you have a link to where I can buy the 2mm wire?
      • domp444
        • Jul 2009
        • 846
        Oh wait, I think I found what I need...
        Will that be long enough though? I need it for my Mystic C5000 M.
        • johnson22456
          Counting down the days...
          • Jul 2008
          • 218
          .078 is 2mm in inches. I think you need a really stright stuffing tube to run a wire drive.
          Hpr 115, Neu 1521 1.5d x2. Delta force Pirate, Insane 45" Neu 2230
          • domp444
            • Jul 2009
            • 846
            Are you going to be running wire drives in your HPR 115?
            I saw the link, and all of the wire drives are with 3/16 shafts. Is there anywhere I can get just the wire?
            • LarrysDrifter
              Big Booty Daddy
              • May 2010
              • 3278
              You can get stainless wire at LHS.
              • domp444
                • Jul 2009
                • 846
                I'll check if they have it, thanks!
                • johnson22456
                  • Jul 2008
                  • 218
                  No, the hpr drives are set up for a .187 flex shaft. I like the flex for there strength, but the wire is easier to take care of.
                  • domp444
                    • Jul 2009
                    • 846
                    Ah, you're lucky. This wire drive stuff is confusing me. I took a look at the site you sent me and I read the info about wire drives. They seem a lot more complicated than flex shafts. We'll see. Hopefully all goes well :)
                    • johnson22456
                      • Jul 2008
                      • 218
                      Good luck. The wire drive was one of the things that concerned me about the MHZ mystic. You'll get it figured out, we got all winter to get them running.
                      • domp444
                        • Jul 2009
                        • 846
                        I didn't even know about it until now. That's true, it'll be an interesting winter :)
