Monster 2000 ESC cooling
  • jmsask
    • 176
    I have a monster 2000 ESC I just got when I got it it had cooling on one channel on the top I added lines to it on top and sealed it with artic silver I then took the bottom cooler off and opened the channels to flow one to the next I then used thick plexi glass folded on each end drilled holes for inlet and outlet and sealed it with 30 min epoxy.
    My question is did I waist my time or is it a good to get as much cooling to it as I can?
    Joe
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1750
    Not to knock your design any but it looks much more prone to leak than the first few pics. Were you having heat issues before with the first pic setup?
    • LarrysDrifter
      Big Booty Daddy
      • May 2010
      • 3416
      I ran mine the exact same way you have your in pic #2.I had no water cooling on the bottom.Ran it on 8s and it wasnt even warm.
      • jmsask
        • 176
        I will be running 10S X2 =4 4S 5000ma Hyp and 2 2S 5000ma Hyp with a little screamer in a 53" Cat. From what I found searching is that there is lot's of heat in a setup like this. I thought if I did as much cooling as I can before install it I may have less problems later. I did test to make sure it wont leak with a pump from a swiffer mop it shot a stream of water 4 feet and no leaks yet.
        Joe
        • LarrysDrifter
          Big Booty Daddy
          • May 2010
          • 3416
          You should be good then.Can you buy a swiffer pump by itself or did you rob wifes mop?
          • jmsask
            • 176
            thought you said can buy one..........
            • jmsask
              • 176
              OOOP's......I told her I was fixing it.....wink
              • carlcisneros
                • Jan 2010
                • 1237
                Oh gawd!!!!!!!!!!!!!!!!! Lol
                • Flying Scotsman
                  Fast Electric Adict!
                  • Jun 2007
                  • 5195
                  I run mine with no cooling on 8S.....the heat sink is huge and does the job.
                  Douggie
                  • CornelP
                    • 793
                    I did a similar job:
                    http://forums.offshoreelectrics.com/...t=monster+2000
                    and, even with a 580 9L on 6S with a 647 it was cold... the motor was boiling, but the ESC was ok. I suppose we are doing this just because we can, not because it's needed...
                    • carlcisneros
                      • Jan 2010
                      • 1237
                      who makes these things anyways?
                      • CornelP
                        • 793
                        You find them under the Turnigy brand, but are made by Hifei. Hifei also makes a more interesting model, with an integral data logger, but I've only seen it on their website.
