What prop?
  • NorthernBoater
    • 869
    What prop?
    I have a blizzard rigger running a Lehner 5000XL on 2s2p. What prop should I run.
  • Jeff
    • 233
    For racing? Start with an octura x632 and if temps stay down you could go up to x435.
    Jeff
    I try and avoid paste eaters.
    • andym
      More Go Than Show Prop Co
      • 2454
      I agree a x632 to start and as Jeff says if temps are ok try something a bit larger, maybe a y535 would have it realy moving.
      • Jeff
        • 233
        The 435 is a big step up from 632, it has alot more blade area. The next would be the 535 like Andy say's. Then after that if you have your hull set up and runing cool would be the m435/3. I have never had good luck with the lifting type props(732,p735.930 ect,ect.), it is much easier to set up with x,y or m props. Just a little positive propshaft angle and it should be fine.
        Jeff
        PS: These are for racing! For sport use a x432.
