I have a spare Leopard 4074-2200kv, Is this motor to much to put in a DF knock off hull. Its a Hor 25" deep v i think its also called a Prince. I would be running it on 4s. Thanks
DF knock off 25"
it will be a absolute missle thats for sure... a little big for a df25, its the perfect motor for a df29...... but it will work... just make sure you are pointed in the right direction when you pull on the trigger :)Originally posted by martin View PostI have a spare Leopard 4074-2200kv, Is this motor to much to put in a DF knock off hull. Its a Hor 25" deep v i think its also called a Prince. I would be running it on 4s. Thanks
I have that motor in a DF33 copy and it's high 40s with a m445 and I still have A LOT more props to test. It can swing a decent size prop. Something like a ammo 2300 3s or 4s maybe better for that hull or a CC 1512 1y on 3s. Do a search on this site of delta force 26's and see what everyone is running. UL-1 power would also work well, same with SV27 power on 4s. The new gold can SV27R motor, with a ul1 esc on 4s would also run very very well. JMO
Originally posted by Diesel6401 View PostI have that motor in a DF33 copy and it's high 40s with a m445 and I still have A LOT more props to test. It can swing a decent size prop. Something like a ammo 2300 3s or 4s maybe better for that hull or a CC 1512 1y on 3s. Do a search on this site of delta force 26's and see what everyone is running. UL-1 power would also work well, same with SV27 power on 4s. The new gold can SV27R motor, with a ul1 esc on 4s would also run very very well. JMO
I only recommend the smaller props if he decides to run the 4074, as the boat will be plenty fast with the smaller prop (on 4s) and probably handle much better..and if he already has that motor and doesn't have the funds for another (but you could sell that motor in a hurry in the SS)..... a big prop on a 25" mono hull will probably be a little rough handling.....Last edited by JMSCARD; 11-26-2010, 10:15 PM.
For what it's worth, my prince is running the Miss Geico esc/motor and I got 42mph on her today running a m645 on 4s. No heat issues at all.FE BOATING: Less like a hobby and more like an addiction!
I think he meant that a v hull has more friction or drag on the water than cats or hydros so they draw more amps with the same set up?SV 27,brushless mini vee,renegade rigger,twinstorm,micro drifter,super hawaii , 1/12 miss budwieser
Well he is right, just didn't have anything to do with what anybody was talking about.......FE BOATING: Less like a hobby and more like an addiction!
