genesis leporad combo
  • Jabbo
    • Jul 2009
    • 495
    Thinking of putting a leporad 2474 2200kv in my genesis cat has anyone run this combo with a hydra 120 on 4s. How were the temps what prop ect.
    Thanks for any info
    jeff
  • Diesel6401
    Memento Vivere
    • 4391
    Thanks for any info
    jeff
    - Diesel's Youtube
    - Diesel's Fleet
    • Jabbo
      • Jul 2009
      • 495
      Oops 4074 2200kv. Leporad on 4s hydra 120
      • FighterCat57
        "The" Fighter Cat
        • Apr 2010
        • 3784
        4s w/120a ESC will max out and eventually melt at a constant 1700 watts.
        Probably best to use the Hydra 240 ESC or the T180 or SF200 & w/m447 prop on 4s2p
        It's a pretty solid 3000 watt setup.
        • Diesel6401
          Memento Vivere
          • 4391
          Yup I would I agree. I run mine with a m445 4s2p on a T180. 120 is just cutting it too close.
          - Diesel's Youtube
          - Diesel's Fleet
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3784
            Yeah, actually the m445 would be a bit easier on the electronics and a better place to start.
            • iamandrew
              • 576
              Im also thinking about changing the engine in my boat but im unsure what to get, because im putting in another Hobbyking order I was looking at their KB 45 's but wasnt sure what one to get!
              Ive got just a 38mm brass prop and standard engine, but the T180 esc, with ex bec and 2 x 40C 4000 MAH 4S Batteries
              I ran it for almost 10 minutes today (before the lake got choppy), ESC was cold, batteries cold, motor was warm, but not hot
              • LarrysDrifter
                Big Booty Daddy
                • May 2010
                • 3416
                I have a KB45 1600kv motor with cooling jacket and a motor coupler ran once Ill sell for $55 shipped.Motor runs great.I can ship it Monday.
                This motor will push the Genesis very well.I ran it with an Octura X445 and went 59mph.
                • iamandrew
                  • 576
                  yeah but what batteries and esc were you using
                  • LarrysDrifter
                    Big Booty Daddy
                    • May 2010
                    • 3416
                    Turnigy 180 speedo and two Turngiy 3s 5000mah 30c packs in series.
                    Higher voltage,less amps,less heat,more fun.
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3784
                      That's the right philosophy!
                      • LarrysDrifter
                        Big Booty Daddy
                        • May 2010
                        • 3416
                        Yes sir!!
                        • iamandrew
                          • 576
                          so is a 2200kv 4074 with a 45mm prop on 4S going to be much faster than the stock setup?
                          • Jabbo
                            • Jul 2009
                            • 495
                            I don't know how fast stock is but that set up should get in the 50's I hope
                            • tiqueman
                              • Jul 2009
                              • 5866
                              Much. The stocker on 3S if I remember correctly was low 30s. 4S on a switched out esc was in the 38mph range. 4074 may run better on a smaller prop. The Gen doesnt like a large diameter prop as it starts to get hard to controll. Also, mine slowed a bit from a 440 to a 442. A guy at the local club is running a 442 on his, 4074 2200, 4s, and runs mid/ high 40s., I run the 4074 1400 on 6S w/ the 440 and another guy runs the castle 1520 1600kv using a 640. Mine does 51, 1400kv and the Castle pushes it a couple mph faster w/ 1600kv
                              Yes we could all probably push them a bit more, but its nice when things come in under 110 and it pulls (6S 1400) 108A max.
