motor and kv rating for a 33-36"cat
  • carlcisneros
    • Jan 2010
    • 1237
    What would be agood motor for a
    33-36"cat?
    good all around sport running.
    and also prop recommendations would be nice.
    thanks folks.
    Carl
  • wakeboardfusion
    • 514
    Im guessing somewhere in the 8-10xl range
      Not enough information. A 32" HOTR cat will run fine on 4S and a 9XL and an x445, but a 34.5" SprintCat won't. The SprintCat turns a lot better and handles rougher water better. What cat is the OP looking at?
      • carlcisneros
        • Jan 2010
        • 1237
        either an aeromarine sprint cat or a genesis style cat boat.
        thanks
          • 6057
          Leopard 4074 or 4082 for the 36" range is my vote.......................
          • DISAR
            • Aug 2007
            • 1137
            depends on the propeller, if the cat cat run well on small props i.e. 42mm then you need 5-6s and rpm range 30-40k
            if you need big props (like sprintcat needs) then 6s min. and rpm 30k
            motors size NEU 1521,1527, castle 1518,1520 leopards 4082 (4074 for genesis)
            I don't know how the genesis runs, but I 've seen here one with the turnigy 1400kv outrunner (veeery good motor for the price)
            the sprintcat will be more demanding and expensive if you need high speeds (motor,esc 240HV), may even run well with the turnigy 1400kv but better to have the input from someone with same setup.
            my opinion is to go with twins, faster,safer,better handling
            http://www.rcfastboats.com/
            • carlcisneros
              • Jan 2010
              • 1237
              great inputs guys
              thanks much
              just have to figure out what I would like Santa to bring if everything goes
              well.
              Carl
              • tiqueman
                • Jul 2009
                • 5866
                Carl, heres my Genesis, Leopard, 4074, 1400KV on 6S, running a 440. 51.4mph Pulls a max amp of 108.
                • LarrysDrifter
                  Big Booty Daddy
                  • May 2010
                  • 3416
                  If you wanna run a traditional stlye cat such as the Genensis,Id go with a Leopard 4082 1500 kv on 6s with a T-180 and an X442 prop to start.I ran this set-up in my 37" Drifter but with an X445 prop,and went 62mph.Ran really cool with room to prop up.I was very impressed with the Leopard.I dont have a data logger yet so I cant tell you about amp draw and such.
                  • Simon170
                    • 102
                    Just ordered this setup for my 36" Gancia Dei Gancia Good to hear its a good system.
                    Still in dry dock... But planning to get wet soon.
                    • LarrysDrifter
                      Big Booty Daddy
                      • May 2010
                      • 3416
                      I really like it.I ran a 645 prop this past sunday and lost 10mph somehow-and split my hull open.My next prop is an x447,then an x450.I think the longer can makes a little more torque than the 4074,which would be helpful for a mid 30" hull.
                      • carlcisneros
                        • Jan 2010
                        • 1237
                        lots of suggestions to decide on for sure.
                        Thanks everyone
                        Carl
