603 or Solder
  • tiqueman
    • Jul 2009
    • 5866
    603 or Solder
    Putting together a twin boat w/ Castle 1520 1600KV motors. Using 3/16 shafts into stub shafts that if they come undone, Im going to lose bearings and parts that may be hard to replace. Ive not yet used the Loctite 603 but have heard many good reviews. Ive had one soldered cable come undone but thats one too many.
    So which way should I go, and if its solder.. whats the best one to do it with. Currently I just use the "solder for non electric applications" from Ace hardware.
    Thanks,
    Scott
  • photohoward1
    • 1781
    Thanks,
    Scott
    603 will never hold. (Good Stuff but no way) The shaft needs to be SILVER SOLDERED OR BRAISED. Some guys love making there own cables an are very good at it. Not me! I buy good ones from reputable dealers. Offshore would be one.
    • carlcisneros
      • Jan 2010
      • 1237
      Or if they are in stock, Areomarine sells them as well.
      Carl
      • tiqueman
        • Jul 2009
        • 5866
        I need to assemble them myself, into the prop shafts that came w/ the drives. And they have to be the type that the cable slides into, not like the Hughy cables.
        • bowzr6
          • Oct 2010
          • 18
          These are nice.. and fast shipping.http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
          • graill
            • 407
            Try loctite 648 retaining compound (green). It is NOT a gap filler so you need a proper fit. Really good stuff. Never had a seperation even at high rpm.
            603 is a cleaner type anerobic sealer and weaker than say the 640 series or 680 (some gap fill characteristics) series, which are both stronger by far, you just need very clean surfaces before bonding unlike the cheaper and weaker 603.
            • scoota
              FE DOWN UNDER
              • Dec 2008
              • 439
              I use Loctite 638 here in OZ, High strength retaining compound , High visscosity , i swear by it have not lossed a flex shaft end since using it , its much stronger than solder .. But you MUST prepare & have clean surfaces before using it !!!!! READ this if you do use Loctite
              http://www.offshoreelectrics.com/inf...mble-shaft.php
              UL1- 1515 castle/neu / 240 swordfish
              SV27- with UL1 running gear
              33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
              • tiqueman
                • Jul 2009
                • 5866
                Thanks for the info guys. Im still undecided how I want to do it though..... Gunna go read that link and see if that pursuades me.
                • martin
                  • 2881
                  638 is probably the best one to use as its the strongest with the largest gap filling, 648 is the weakest of the 3 mentioned but has a higher temperature capability which is probably no advantage in this situation. The 603 has better oil tolerance than the other 2. Martin.
                  603 638 648
                  diam clearance 0.1mm 0.25mm 0.15mm
                  shear strength 22.5N/mm 25N/mm 13.5N/mm
                  3260psi 3625psi 1957psi
                  • SweetAccord
                    Speed Passion
                    • 1322
                    Loctite 603 is strong but for small drives like .098 wire drives etc. Loctite 638 is meant for parts with clearances between 0.002" to 0.010" radial. Loctite 680 is meant for parts with clearances up to 0.008". In other words, use 638 for items that easily slip on and use 680 for those that are either a light press fit or slightly looser. 680 should be plenty strong up to 3,500 PSI shear strength.
                    • dana
                      • Mar 2010
                      • 3660
                      i use a pure silver solder. you can get rolls of it at any radio shack. it's generally used in hvac or anywhere high pressure joints are being soldered. also you must clean the stubshaft and flex very well...and use flux, it cleans and helps solder adhear. never had a problem here
                      • tiqueman
                        • Jul 2009
                        • 5866
                        Thats kinda the route Im thinking of going. I just cant seem to get "stuck" on glueing it. Plus if I kink a shaft or something, I can get it undone. I may start glueing some .150 shafts though, just to say I did it.
                        thank you all for the wealth of info.
                        • BHChieftain
                          Fast Electric Addict
                          • 2051
                          I like the idea of the "unsolder" option...
                          I had a situtation where I swapped out a motor on a tenshock mono1 that had a 4mm metric shaft, and with the new motor and coupler the existing flexcable was too short. Luckily the shaft was soldered to the cable and I was able to salvage the old shaft and install a new cable. Good thing as I was unable to find a replacement shaft for that boat...
                          Chief
                          • blackcat26
                            High Speed Junkie
                            • Sep 2009
                            • 1750
                            For what it's worth I use 680 on my stuff and have never had a problem. Knock on wood......
                            • tiqueman
                              • Jul 2009
                              • 5866
                              Chief
                              Yeah Im going w/ solder. After I thought about it, it makes the most sense for my application.
