Esc and motor temps good.Lipos HOT!!!
  • britscoot
    • 721
    Whats the deal with that?
    My setup is castle 1800kv motor and seaking 180esc on 4s.
    5.5 bullets all round.
    m445 prop and the boat is planing well and not running wet.
    2.5 minute runs and she comes in with a hot lipo.
    any ideas oh great ones?
  • Chilli
    • 3204
    What Lipos are you using??
    Mike Chirillo
    www.capitolrcmodelboats.com
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      What's the C rating on the lipos?
      If you're pulling on them too hard, they will get hot. They'll deliver to their max, but heat up accordingly.
      PS- I'm not a great one, but I'm sure one will be along shortly.
      • Make-a-Wake
        FE Rules!
        • 6057
        "2.5 minute runs and she comes in with a hot lipo."
        You mention hot lipo, singular..........just one? If so probably a bad cell or solder.
        • britscoot
          • 721
          I use turnigy 45c mostly which run better than the hyperion 35c i have temp wise.
          I also run 25c venoms.
          they are all getting hotter than i like though.
          How come the motor and esc are cooler?
          What should i do besides cut down the run time?2.5 minutes should be ok.if i run any shorter i might as well get a gas boat.
          • Make-a-Wake
            FE Rules!
            • 6057
            We posted at the same time.....................see above
            • britscoot
              • 721
              most of my lipos are brand new.
              I have expensive lipos and they get hot also.
              • britscoot
                • 721
                5.5 bullets are soldered well.
                • britscoot
                  • 721
                  the lower c rated ones seem to be running less hot besides the hyperions.
                  I'm not happy with there performance.
                  • FighterCat57
                    "The" Fighter Cat
                    • Apr 2010
                    • 3784
                    How hot is hot?
                    1p or 2p?
                    • Boatman
                      • 875
                      What hull? How do you run Full throttle or bashing around? Obviously spin drive shaft by hand and chEck for binding.
                      • domwilson
                        • 4411
                        Need more info. What mah? What configuration, hull, prop, number of cells, parallel or series, etc.?
                        Government Moto:
                        • britscoot
                          • 721
                          hot enough to puff them.
                          nothing binding.
                          1p lipos
                          i run wot as its a fe30 hydro.
                          what would jesus do?
                          to solve this?
                          • chummer
                            • 650
                            Are the cells puffing? Or is it just the shrink wrap? Do you have a temp gun?
                            "IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
                            • britscoot
                              • 721
                              fe30
                              m445 prop
                              1p 4s 5000mah
                              oh and its orange if that helps....lol
