i have an aeromarine predator. its 29" X 11" with k@b outboard unit. should i go outrunner or inrunner? im looking to get into the 40's on a budget. i was thinking ul-1 motor/ esc but im open to other suggestions
whats a good motor for this boat?
I have one and if I were to set it up FE, I would go with the UL-1 setup....cheap and does it's job....
-Kent
I run my predator with the UL-1. Great setup. VERY fast boat.Mini Cat Racing USA
www.minicatracingusa.com
Hmmmm..........Im guessin' you'll go with the ..........................UL-1.......?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
haha yeah well i was gonna go that route anyways, just wanted some more opinions. i run the ul-1 motor esc in my Ul-1 and supervee and i LOVE them. good reliable fast setup. is it bad for the motor to get wet tho? cause its gonna and there is no cover on the motor
Yep! I bought my boat straight from Remmy at Aeromarine in Seaford, DE around 1993.....Originally posted by dana View Postok. i do love the ul-1 set-up. you have this boat ey..? what speeds are you getting with nitro?
With a highly modded Kaboom a Gardner XXL throttle exhaust and a Garcia Mini Marine pipe, I have had my Predator up to 60+...and that was with the perfect setting, on the pipe, dialed in and the wind was just a breeze down the backstraight blowing torward the boat's transom. Even though it is a fairly heavy tunnel, I watched it that day lift off out of the water like it was a jet airplane taking off and then did a huge backflip and landed on the shoreline right side up (no damages other than a few scratches on the bottom of the sponsons!!!!!
Does your tunnel have just one steering rod?
UL-1 all the way with this one Dana....
The water will not hurt the motor bro...in fact I watched Mike L. (cybercrxt) run his upside down a few times after it flipped over just to see if he could bring it in....
-Kent
Oh, ok, just curious about that....I just went off of the blueprints they gave me when building mine...no worries....
