Need some good advise here. I am running 2215's (8mm shaft's) to .250 flex cables and I currently have both the octura collet style and I have the Jeff Wohlt alum. couplers that use a few set screws around the coupler. Which are people having luck with? I have only tried the collet style and they are slipping and VERY stinking hard to tighten. I am almost having to pickup a 35lb boat when I loosen them to get my drive shafts out. However I really wonder if the set screw type are going to be any bettor as far as the screws coming loose. Any thoughts?
Big power coupler's questions
Mine should not slip with 6 screws on the cable. Once you solder the end of the cable it should be fine. I can also put in the pointed set screws but they are a little hard on the cable but lock on well.
ok, yes you are correct. I have the ones with 6 screws to the cable. I have no solder at all yet on the cables so I will do so and try yours. Thanks for the assurance. They actually are so pretty and well made I didn't want to use them
sorry to doubt ya Jeff cause these collet style are terrible in my opinion
Not at all... Some collets work better but the ones I have sold are mamoth and I can't imagine they balance well but maybe they do.
Set screw are lighter, balanced better and should be able to take the power....if not I can turn them from a higher grade Aircraft Alum...much harder but can also become brittle.
Yes, the cable MUST be soldered. I would use a good silver solder so it is hard. Also, always use loctite thread locker.
I can also make them with much larger set screws...currently I use 6/32 but could go to 8/32. 6 of those is a lot of holding power.
