I want to run 8s on this motor, but need a 5mm shaft size, can ose special order one, or has anyone else used this motor w/5mm?
NEU 1.5Y 850 Kv Question?
I assume you are referring to a 1527 1.5y.................here's what it says on the OSE page:
if you don't see the motor wind listed you need with a 5mm shaft, we can special order these motors with 5mm shafts. It takes approx. 3-5 weeks to ship. Contact us for more details.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
There was a time a few years ago when the Octura 8mm flex hexes had excessive runout while the 5mm versions ran true. This is no longer the case, I have several 8mm Flex hexes which run true at 40,000 rpm. Get the motor with the 8mm PTO shaft.
