poor throttle response
  • RIPFENCE
    • Sep 2009
    • 1577
    hi all,
    i am bench testing my cyberstorm and i am getting some weird throttle response..my setup is a spektrum dx3e and one of the new marine mr3000 receivers..i am using the swordfish 240hv..i have my receiver binded and everything is working..the problem i get is a delay in throttle response..when i pull the trigger on the radio it takes a half a second or so for the motor to start turning is not instantaneous like all my other setups..anyone had this happen?
    thank you
    rip
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
  • scoota
    FE DOWN UNDER
    • Dec 2008
    • 439
    have you calibrated the TX with the ESC , if u have try adjusting your throttle trim on you transmitter ..
    UL1- 1515 castle/neu / 240 swordfish
    SV27- with UL1 running gear
    33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
    • RIPFENCE
      • Sep 2009
      • 1577
      yes i did the calibration with the swordfish and adjusted the trim....still get the delayed response
      • BakedMopar
        No Mo Slipah
        • Sep 2009
        • 1743
        All of the HiFei escs that I used have mushy throttle responses. Even when it gets up to speed and you get off and back on it has a profound delay. Even when you change it to fast start.
        • RIPFENCE
          • Sep 2009
          • 1577
          its strange though because i have used some other swordfishes that did not do that...i will have to do some expirimenting with different combos with receivers/esc and try to narrow down the problem..i cannot believe its 50 degrees in maine today!!! i will be able to run tormorrow!!!
          • BakedMopar
            No Mo Slipah
            • Sep 2009
            • 1743
            Damn. I think I'm going to have a heat stroke. It's so humid today. It's mid 80's outside and over 90 in the garage. Lol.
            If you find a fix let us know.
            • sailr
              • 7128
              Where do you have the 'start' programmed? Soft Start, hard start, etc?
              Mini Cat Racing USA
              www.minicatracingusa.com
              • RIPFENCE
                • Sep 2009
                • 1577
                good idea...i will check that before i run tomorrow..thanks sailr
