ok so these are both 42mm props but what is the pitch difference between them I am stumped here and wanna try the x442 but have the 42x55 already????
x442 vs. 42x55 grim
No, it depends on many other factors...welcome to the FE world....it can drive you crazy.
Douggie
I have both and used them on my JAE rigger.
Grimracer looks a bit faster, but haven't put GPS in...
Prop shape is totally different, de X442 is a sharp tipped prop measuring 42mm in the tips.
The Grimracer has rounded tips and seems to measure more like 44mm then a 42mm.
Blades are larger also.
Not sure about lift difference on both props.
On my JAE the load on the setup is not much different, both props heat up the setup about the same and runtime is comparable also.
Tip shape by itself is not a factor. The fastest nitro props (130 mpg) have rounded tips. The fastest FE props (140 mph) have pointed tips. Most FE-30 drivers find rounded tips faster. But it is overall blade design matched with a specific motor/hull that matters.
