Hey guys... i just got a couple new boats... and trying to figure out a good set up on them.. the one is a Vac-U-Pickle and it needs pretty much all the hardware.. Need to figure out how to post a pic...lol
New boat!!
Did you buy the hydro used? from what I can tell there is a hole on the left of the strut bracket for the rudder push rod, did you drill this hole?? And the 1/4"hole on the right might be for the drain plug?? Hard to say, you need to tell us more about the holes/hull. and if you have drilled any of them.
Originally posted by Krowbar69 View PostHere's the back end...
I'd like to use the hole that are there, already.. can someone tell by looking at it what hardware would work??? ThanksHPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
Nice! Looks good, but I have no clue what the hole on the right would be for. Maybe another water tubing hole for a secondary water pickup?SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
I would get the speedmaster mini rudder for your hydro. Do you have the strut as well?
Before you plug the hole on the left of the strut, see if you can use the hole on the left of the strut to mount your rudder. And then drill for the second hole on the bracket.
I for one would plug that big hole on the right, since you already have a hole for the water pickup going thru the transom above the big hole. Even the water pickup hole is too far away from the rudder.
Originally posted by Krowbar69 View PostNope... i did'nt drill em... thats how i bought the boat... trying to figure out what that hole is for..HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
heres a strut with bracket, IDK if Steve just sell just the strut without the bracket. http://www.offshoreelectrics.com/pro...d=ros-21-strut, heres the rudder http://www.offshoreelectrics.com/pro...d=ros-mini-rudHPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
