What external bec do you use.
  • noodler
    • 33
    I wondering what external bec's you guys use. As of now I have used Castle.Is there a cheaper alternative? Thats a funny banana.
  • driftah
    • 757
    mine is made by otter and is good for up to 26volts I got it for 10 bux works flawless
    • m4a1usr
      Fast Electric Addict
      • 2032
      I have used the HXT's from HK with good success. Under 10$ and good up to 23v. For HV setups I have used the KoolFlight BEC. They work well too. For me I have since changed my thoughts about using a UBEC instead of a Rx battery. I have been switching my hulls back over to a battery since seeing an alarming increase in BEC failures or at least them coming to my attention. My thoughts initialy were the BEC device was better, now since seeing folks having their Rx killed by a failing BEC device I am going back to a pack. And there was a time weight Vs power was an issue which was another reason. Now our hulls can easily carry an extra few ounces and get the reliability of a pack. JMO. YMMV.
      John
      Change is the one Constant
      • LuckyDuc
        Team Ducati Racing
        • Dec 2008
        • 989
        I use Castle Creations and Dimension Engineering BECs. http://www.dimensionengineering.com/ParkBEC6v.htm
        • properchopper
          rcgoatbuild@snotmail.com
          • 6958
          John
          I'm with John on this. Having had at least a half dozen UBEC failures, three of which shot battery voltage to the Rx & servo & taking out both, I'm currently using the internal BEC's in all five of my setups (which BTW are all 4S). I'm now switching over to my Fut Rx's (at @ $ 85 ea.) which hurt a lot more than smoking a $20 Tactic which I use for sport. { the Fut. Tx has ten model memory and I can preset trims for oval racing-not needed for sport}.
          Then again, Mr. Turner [Fluid] recommends and uses a battery pack and he certainly knows his stuff.
          • Gerwin Brommer
            • Dec 2008
            • 918
            I'm a nono to all this stuff, so I have another question.
            I'm using HV-setups ( 10S ).
            For the RX i bought an Turnigy 8A bec, and I'll feed it by a separate 2s pack.
            Will this decrease the risk of destroying the ext. bec ?
            • pda75
              • 42
              i am using the HV from turigny (HK) in 10S set up. I am using 3 of them. they never failed.
              Regards
              Pierre
              • properchopper
                • 6958
                If your Rx can handle 7.4V, [check it's specs - it likely can], just go direct from the
                2S pack.
                • noodler
                  • 33
                  thanks for the info guys
                  • Gerwin Brommer
                    • Dec 2008
                    • 918
                    Properchopper.
                    I'm using Futaba Fasst 2.4 , 603 receiver , with digital servo's ( hitec )
                    hs 5745 and hs 5755 mg, 6V servo's, so I'm afraid they can't handle more volts.
                    • GeoVW72
                      • Jun 2010
                      • 258
                      2S pack.
                      I'd be careful on that. I have seen many spektrum receivers fail, and they are rated for 9v. fully charged Li-po is 8.4v
                      Team Boca Bearings
                      S&G Design
                      • properchopper
                        • 6958
                        Properchopper.
                        I've run this Rx combo before ; others have also. Shouldn't hurt servos either. Also, the Tx pack has been in use for over two years with no issues. Just my experience, don't try it if you're not comfortable.
                        • Gerwin Brommer
                          • Dec 2008
                          • 918
                          hm, thinking about this topic I decided to test how the ext. bec funtioned with my
                          rx and servo's.
                          Brand new Turnigy 8-15A bec, and brand new 2s lipo.
                          No rx attached , connected the bec to the lipo , POOF !
                          • 785boats
                            Wet Track Racing
                            • 3169
                            I always use the BEC in the ESC myself, but I do have a couple of Turborix ESCs that don't have an internal one & this is the UBEC I use with them.
                            http://www.hobbyking.com/hobbycity/s...dProduct=10313
                            Never had a problem.
                            Cheers.
                            Paul.
