Leapard or Neu for triton
  • BHChieftain
    Fast Electric Addict
    • 2051
    Cheif-
    I have a Leopard 4082 1300kv I actually ran in that boat (too low kv to get any speed on 4s though). I ran it with prather s220, s225, s230, x445, and even tried an x452. It was fast with the bigger props for sure, but it hopped alot when turning and was quite a wild ride.
    On 4s with the Leopard 4074/2200kv I ran a s220 and it was fast, turned great, and drove perfectly. Very big difference when compared to the heavier setup with the larger prop. I would try to stay with a s215 or s220 myself...thats definitely where that boat handled the best.
    The 1518 on 4s2p would be a great setup. Decent speed, lower temps, and longer run times.
    P.S.-
    If you run 4s2p, you will probably have the best luck putting 3 of the 4 lipos in the left side as far back and close to the motor as you can get them, then run one pack on the other side. That seemed to work the best for me.
    I'll give that a go. My son will be happy to finally keep up with the big boys...
    Picked up the 1518, cooling can, and ESC today...
    Chief
    • Gerwin Brommer
      • Dec 2008
      • 928
      Too late to suggest another motor, too bad.
      A friend of me just finished his lizard-build, similar boat as your Toysport.
      He now runs it with a Turnigy T600, very cheap, and runs fast !
      • Alfa Spirit
        • 2183
        A Castle 1518 or Castle 1520 with 2 x 4S or 2 x 5S batteries in parallel
        • BHChieftain
          • 2051
          I should get the motor in a few days and I'll let you know the mounting screw spacing. I was assuming standard 25mm, but maybe not...
          Chief
          • Rumdog
            • 6667
            Yep, it will fit in the standard mounts sold here at OSE
            • BHChieftain
              • 2051
              The motor literally just showed up in the mail 5 min after I posted...
              Mounting holes are 25mm spacing.
              Chief
              • bigwaveohs
                • 606
                Originally posted by Rumdog View Post
                I used the 1518 in my Rico 31" mono on 4s2p and 5s2p and it hauled ass! 58 mph on 5s.
                How did you mount that motor with the fins/watercooler? Only on one end?
                I let the dogs out...
                • Rumdog
                  • 6667
                  Yes. I epoxied a wood wedge to the hull to support the end as well. Probably not necessary. We use these things in trucks and buggies that fly over huge jumps and flip like crazy with no rear support, so Ina boat I see no real need for it.
