6S ESCs
  • Diesel6401
    Memento Vivere
    • 4391
    Hey guys don't forget Steve is sell the 180s http://www.offshoreelectrics.com/pro...er-seaking-180.
    - Diesel's Youtube
    - Diesel's Fleet
    • Make-a-Wake
      FE Rules!
      • 6057
      Yeah..............the Turnigy is the same as the Seaking.............i just recieved a Seaking 180a from him last week. Come to think of it, the Turnigy probably is the Seaking.
      • Diesel6401
        Memento Vivere
        • 4391
        Yes the turnigy IS the seaking, remember hobbycity makes NOTHING of their own. Everything is rebranded!
        - Diesel's Youtube
        - Diesel's Fleet
        • Rumdog
          • 6667
          34" twin cat. Castle/Neu 1520's. x447 CR props. 6s1p per side. Seaking 180's. New cells. New motors. New esc's, with short power leads. second run, plug in tape up, hit throttle.....bang! starboard side esc up in smoke.
          Ususally I do not run esc's to max specs. After asking around a bit, I decided to give it a go.
          NEVER AGAIN!!
          You'll regret it when it happens to you!
          • GP73
            • 546
            Rumdog: builtin BEC or external?
            • Flying Scotsman
              Fast Electric Adict!
              • 5195
              I will state this only once as the Idiot Scotsman...DO NOT RUN ANY ESC AT MAXIMUM STATED SPECIFICATIONS.
              Douggie
              • Rumdog
                • 6667
                External rx pack. bec's disconnected. I've owned at least 8 of these esc. This is the only one, of ANY esc I've owned that I've ran at max voltage. Needless to say, it won't happen again!
                No matter who says it's fine.
                Unless you like expensive, stinky gooey messes.
                • Flying Scotsman
                  • 5195
                  Rummy, been there and done the same.....THE SMELL...THE SMELL.
                  Douggie
                  • keithbradley
                    • 3671
                    Rum, Douggie,
                    Any thoughts on 5s on my swordfish 120's? Turning twin 1518's with cr x447s on a 30" cat
                    www.keithbradleyboats.com
                    • Rumdog
                      • 6667
                      Can't say on the Swordfish. I ran 5s on the Seaking dozens of times without issue though. Start with 442's though.
                      You may be pushing it with the amps
                      • Flying Scotsman
                        • 5195
                        NO WAY
                        Edit
                        Those are huge props and you will have a stability problem also, and why twin motors...what cat?
                        Fluid, your thoughts?
                        Douggie
                        • GP73
                          • 546
                          I thought the issue was the amperage, not the voltage... I guess I won't be running my CC 1520 on my T180 after all...
                          • Rumdog
                            • 6667
                            Originally posted by Flying Scotsman View Post
                            NO WAY
                            Edit
                            Douggie
                            Oh, Those motors will spin those props no problem Douggie. And twin motors to correct stability problems
                            • GP73
                              • 546
                              As far as I understand the theory: more RPM = less prop.
                              With a CC 1518 @ 1800Kv I would use a "large" (42 to 47mm) prop on 4S (@ 26K RPM) and a smaller one (35 to 41mm) on 5S (@ 33K RPM).
                              Also the CC 1518 is rated @ 120A, I would use at minimum a 180A ESC or possibly even a 240A.
                              Rum, Douggie,
                              • Rumdog
                                • 6667
                                Amp ratings on motors mean relatively nothing. They can, and will pull way more amps. Especially in a boat. On a twin cat, running twins significantly reduces amp draw.
                                I used to run a 1518 in my Rico mono on 5s2p with a x548! Very reliable, and fast combo. Anything under 42mm probably wont even load that motor.
