boat setup help apparition
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    #31
    Originally posted by Alexgar View Post
    1515
    That's awesome that the 1515 fits in the new hull without hitting the hatch. It did not fit in the old style Apparition.
    • Alfa Spirit
      • 2183
      #32
      CC 1515 or CC 1512 is ok. I run 2 x NEU MOTORS 1512 in a Genesis
      • Alexgar
        • Aug 2009
        • 3701
        #33
        it barely fit the hatch touches the motor
        • kevink
          • Jun 2010
          • 47
          #34
          I am running a kershaw designs 2340kv motor on 4s in my apparition and recently gps'd at 55.1mph with m445 prop and Turnigy 180. Temps have been great, from 100-120 degrees. Fightercat is absolutely right about treating the hull while it is new. The wood will get soaked and separate from the hull. Also, do the mod that tiqueman recommended. I switched to .150 thinking that the slight difference in size from 4mm would be negligible.....wrong. After three minutes, the inside is soaked due to the slightly smaller .150 flex in a 4mm tube. I will be switching to .250 brass next.
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3784
            #35
            Careful with the seal on the strut rudder. With a one piece, you leave a gap. With a two piece cable, there is no gap and should be snug but still spin freely to prevent leak.
            • kevink
              • Jun 2010
              • 47
              #36
              Thanks for the tips. Do you think the stock 4mm shaft is strong enough for the setup I am running. I have already switched to the .150 with 3/16" shaft, but I now get lots of water in the hull. Left a small gap at the strut to allow for flex shortening. I'm thinking of either re-installing the 4mm setup or replacing and reglassing the proper brass tubing for .150. Unless anyone can make a 4mm flex with 3/16 prop shaft. Or......maybe that last one was just a silly question.
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3784
                #37
                I can help you workout the stock setup. I've had them hold up with the 1512 2650 on 4s, so you should be OK.
                BTW, 4mm is bigger than .150, by .007". They are basically interchangeable.
                • kevink
                  • Jun 2010
                  • 47
                  #38
                  Did you get a lot of water in the hull with the 4mm setup? When I switched to .150 thinking that the size difference was negligible, I started getting lots of water. Bath tested and cannot find any other leaks. Put shrink tubing over the strut/tube joint and silicone tubing over the flex by the coupler.
                  • FighterCat57
                    "The" Fighter Cat
                    • Apr 2010
                    • 3784
                    #39
                    Actually the water leak doesn't have to do with the cable/brass size. I use 078 wires in the 6mm tubes and don't have any leaks. Hugh air gaps there.
                    It has to do with the teflon seal at the bottom. If your washer is bigger than the strut, it will build up water pressure in the brass tube and leak. If the prop dog is bigger than the strut, it will do the same.
                    The key is to be certain the prop dog will be tight against the strut bushing almost compressing the teflon during run. With a 1pc cable, it will tighten up and shrink a bit. But, with the 2 piece, the cable doesn't pull the prop shaft, so the prop dog needs to be snug against the strut bushing. I do this by tightening the prop nut in very small increments until the gap is gone, but the shaft still spins.
                    Also, if the brass and strut are different sizes, the water will pressurize the tube at the bottom as well. If you're using a different strut with the stock tube, this might happen.
                    Post a photo of the struts setup from the side when you get a chance.
                    • kevink
                      • Jun 2010
                      • 47
                      #40
                      Wow. Great insight. I will recheck my setup tonight. I'm using a strut from a miss geico with speedmaster bushing. I'll check the prop dog as well. Thanks a bunch. I will post pic tonight.
                      • kevink
                        • Jun 2010
                        • 47
                        #41
                        Here's a pic of the strut. Thanks for the help. Read your Apparition build and looked great.
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3784
                          #42
                          OK, check area #1 under the heat shrink. If the brass isn't really snug into the strut, use some silicone to fill the gap and seal.
                          Area #2 should be snug, no air gap but still spin freely.
                          OPTIONALLY if still leaking you can increase the air gap #2 to 1mm and epoxy the cable into the hard prop shaft to make it a single cable/shaft setup. Then it will pull the hard shaft taught.
                          • kevink
                            • Jun 2010
                            • 47
                            #43
                            Thanks. I'll try the silicone to seal the strut to tube. I left a small gap since I am running a one piece flex .150 to 3/16 shaft. Appreciate the suggestions will try again tomorrow.
                            • Alexgar
                              • Aug 2009
                              • 3701
                              #44
                              ran today in my dent pond , its been raining for days and on 6s with the 1515 cc and a etti 150 with ul1 prop its crazy fast
