sealing the ESC ends
    • 9481
    Originally posted by andym View Post
    This is what I use http://www.mektronics.com.au/index.p...mart&Itemid=57
    Have found it great and use on esc, RX and servo boards. No water induced failures since I started using this a few years ago.
    There are other brands on the market that do the same thing and it is available every where
    Sweet, thank you
    Looks like I just spray it on and let it dry?
    • andym
      More Go Than Show Prop Co
      • 2454
      Yep, I just blow the part off with air to make sure clean and give a light coat, wait a few minutes and a light coat. I give it three coats.
      One thing though do NOT shake the can before spraying. If you read the directions it is on there in small print, I believe it foams in the can spraying small bubbles in the finish that could let water in.
      Cheers
      • JimClark
        • 5913
        Here is what I have
        Billy Graham
        • oscarel
          • Dec 2009
          • 2373
          My local Fry's sells it. With the spray on are you able to get it between the layers of boards?
          • andym
            • 2454
            yes
