can I run this setup in a df29 or is it a no? I wanted to maybe use a 42x55 grim prop or can I go bigger and not smoke the esc? like the octura x445.........cause the esc is only good for 60 amps,I just wondered if the motor will draw too much for the esc kinda
ul-1 esc with 9xl motor
I smoked my long-time favorite CC80 (watercooled) with a 9XL in my Titan 29. Does that tell ya' anything ? Best to go bigger.Originally posted by driftah View Postcan I run this setup in a df29 or is it a no? I wanted to maybe use a 42x55 grim prop or can I go bigger and not smoke the esc? like the octura x445.........cause the esc is only good for 60 amps,I just wondered if the motor will draw too much for the esc kinda
I used to run a M445 but found a nicely sharpened 442 was just as fast & pulled less amps.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
A 9XL will smoke it..............NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Not that it means anything, but I ran a 9xl on 4S on a SV using a 45 amp SV controller for 2 years on a 45mm K prop.....no issues at all.Grand River Marine Modellers
Wow...some people have all the luck!Originally posted by Doby View PostNot that it means anything, but I ran a 9xl on 4S on a SV using a 45 amp SV controller for 2 years on a 45mm K prop.....no issues at all.
"IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"
