LiPo + brushed 550 motor help
  • ScarabChris
    • Oct 2010
    • 812
    OK Chris, so you're taking the brushless plunge afterall! If you go with the Feigao 540s you want the 16s for 3s, you dont need huge rpms, and it comes with the 1/8" shaft. The 16s will give you around 28,000 rpms unloaded and around 23,000 in the water. That should give you a nice performance boost and they are a direct bolt in to your outboards. The most crucial part is the length(or height in this case), they will fit nicely under the cowls. The 120a speedos seem like overkill to me.......but you cant go wrong with a bunch of room there.
    So I guess that means this motor....
    540 16S 2,400 RPM/Volt 1/8" Shaft
    Ok so maybe an 80 amp?
    Originally posted by befu View Post
    Just saw this in the comments section under that video you posted of the twin cat:
    hey ! thease are just the hobbywing car brushless systems from ebay!  there are two types 13turn & 9turn both with a 35 amp speedy! they are both great just keep the grease up to all parts to keep the salt from killing it all dry it all out when you get home from boating .. have fun
    sounds like he is running that on 35 amps esc's. Might not go that small, but watch how much power you put on those gears.
    Have you done any searching on the web to see what brushless motors others are running on these outboards? somebody had to do something and write about it.
    I have searched high and low to find info on any electric outboard, not much out there.
    • ScarabChris
      • Oct 2010
      • 812
      First things first.
      Take a look at what you are running right now, the performance you are getting and were you want to end up.
      Speed wise, how much do you want to increase it?
      Power: When running NiMh, what is the size of the pack and how long does a full charge last? You need to figure out how much amperage you are pulling. From that, you can estimate the power the motors are consuming and putting out.
      How fast are the props spinning also. If you pull a motor and have a prop tach, you can estimate the KV of the current motor.
      Then you start doing math. You estimate the rpm of your motor and how fast the props are spinning. You guess at how much faster you want to spin them, then you decide what lipo you are running (you have one already). From that, you pick a new KV (rpm/volt). Once you have that, you can select a motor to match your guess at wattage.
      first thing, I would try to find out what wattage you are running, that will give you a starting point. What is the amp rating of your current esc? Is there one or two? those motors on the cat were being sold with 35 amp ESC's, so you might not need a 120 amps ESC.
      need some basics before you start buying big dollar parts.
      Brian
      The safe setup is two 8.4 volt 7 cell NiMH batteries and two Pro Boat ESCs all from OSE. This is a safe setup but not impressive at all with speed.
      Swapping out the NiMH batts with a pair of 3000 mAh 3s 11.1 volt Lipos kicks it up a notch (or two) but smokes the motors.
      • JMSCARD
        • Mar 2010
        • 4174
        glad you are getting the right info.... :) sounds like the 16s motors are your setup.... I always like plenty of room esc wise.... and the 120 turnigy marines don't break the bank at $49 a piece... they do make seaking 60's and 90's that are reasonable too... I like the turnigy/seaking because they are easy to set up and program.... If you get the 120's you will have plenty of headroom and you can use them down the road on alot of different projects.... good luck this sounds like its gonna be quite the setup!!
        • ScarabChris
          • Oct 2010
          • 812
          I don't mind buying more ESC than I need, but how about reverse? I want the boat to have reverse.
          YES!! Looks like the Turnigy has reverse. Where is a good place in the US to get them?
          • Make-a-Wake
            FE Rules!
            • 6057
            As JMSCARD mentioned, the Turnigy 120a is a super value, i own several of 'em, they are simple-setup workhorses, and at $49 from Hobby king.............no brainer. Pay for the EMS shipping and have them to your door in 6-8 days max.
            If you want one from the states, here is the 90a version, plenty for the 16s which correctly propped, will pull no more than 50 amps.
            Pricier than HK.........free shipping though. The place is in California.
            • ScarabChris
              • Oct 2010
              • 812
              OK cool. But looking at that graph does it mean reverse won't work on 3 cell LiPos?
              Sorry for all the questions, I just want to get this right.
              • JMSCARD
                • Mar 2010
                • 4174
                No sir chris that just is a graph for the different program steps... the first step you choose if you want forward or forward and reverse....next step is your LVC (low voltage cutoff) and what you want it set for.... third step and so on... you will have reverse no matter how many cells you throw at it..... get the 120 though from hk.... a 90 amp is sooooo.... in the middle and its around the same size footprint anyhow... JMHO....
                if you are going to pay $67.95 for a 90 amp seaking from the states I myself would buy the swordfish 120's from steve for $69.... they are another great esc.... and you can get a program box from him as well....
                • ScarabChris
                  • Oct 2010
                  • 812
                  OK you convinced me. I'll get the 120s from HK. I guess I need a programming card too?
                  • Make-a-Wake
                    FE Rules!
                    • 6057
                    I say no...................They are so easy to use and program with the TX............just a set of beeps..............sheesh.....i have 'em memorized!
                    Just my opinion though.............
                    • ScarabChris
                      • Oct 2010
                      • 812
                      LOL....beeps? I better get the card for 6 bucks.
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        Well..............didnt realize they were only 6 bucks.................i just dont need the card myself, thats all....................
                        Order your goodies!!!
                        • JMSCARD
                          • Mar 2010
                          • 4174
                          I agree make a wake... super easy to program... but I still have one of these..
                          they work with the turnigy/seaking 180's too... they make it sooooooo easy.... and since you are getting the other stuff anyhow whats another $8.....
                          also since you are fairly new to this brushless thing I would definately get the program card and take one less hassle out of your life.... I hear ya as far as easy with the TX again make a wake.... but both you and I have probably pulled our hair out programming other esc's in the past so these seem simple.... ever programmed a etti? I lost a bunch of hair that day....
                          • JMSCARD
                            • Mar 2010
                            • 4174
                            LOL... guess I was a little slow responding...LMAO...
                            • Make-a-Wake
                              FE Rules!
                              • 6057
                              Yeah..............they are the least frustrating ESC ever in my opinion...........
                              Plug and play! I tried progarmming a "suppo" once.............for a week.......thought i was in Hell..................sold it........
                              • ScarabChris
                                • Oct 2010
                                • 812
                                OK....wow hours of research to come to this decision, thanks a million to you guys.
                                Just ordered the Turnigy 120s and programming card from HK. Now off to OSE to order those 16s motors and cooling jackets. Yup I'm in it now!
                                OSE is out of the in hull water pickups, anyone know where I can order them?http://www.offshoreelectrics.com/pro...prod=ose-80400
