Engine
  • kal1b3r
    • 46
    Engine
    i am currently looking for a nitro engine or a 2 stroke engine for my other boat. does anyone have any suggestions on which one to get, so far all i found was this.
    http://www.rcplanet.com/ProductDetai...Show=TechSpecs
    specs if link doesnt work for you, or you dont want to go on the site:
    Displacement: 0.2 cu in (3.46cc)
    Bore: 0.65" (16.6mm)
    Stroke: 0.63" (16mm)
    Practical RPM Range: 3000-40,000
    Power Output: 2.5 hp @ 33,000 RPM
    Weight: 12oz (340g)
    Distance between mounting holes same side: 0.83" (21mm)
    Distance between mounting holes opposite side: 1.4" (37mm)
    Distance from exhaust center to mounting flange bottom: 1.1" (27.5mm)
    Width not including mounting flanges: 1.2" (30.8mm)
    Width including mounting flanges: 1.8" (45mm)
    Height bottom of crankcase to top of intake: 3.5" (89.1mm)
    Height bottom of mounting flanges to top of intake: 2.9" (73.6mm)
    Length from backplate to end of crankshaft: 3.4" (87mm)
    Length from backplate to flywheel: 2.5" (65mm)
    Length from crankcase center to flywheel: 1.7" (44mm)
    NEEDLE SETTINGS: -High Speed Needle: 1.5 turns OUT from fully closed position per page 20 of manual
    -Mixture Control Screw: Refer to sketch on page 17 of manual.
    This screw can only be turned 90° either way.
    RC boat Noob lol
    http://www.mafiacrime.org/r.php?id=9137
  • ReddyWatts
    • 1756
    Check this one. I bought one of these for a Mean Machine hull. Do not have it installed yet.
    http://cgi.ebay.com/DYNAMITE-32-Mari...QQcmdZViewItem
    Exhaust / parts for the 32 engine. (Click on parts list)
    ReddyWatts fleet photo
