Is a 25 watt Weller soldering pencil good enough for soldering motor/battery leads? Or should I get one with more watts. TIA
Weller Soldering Iron
Tags: None
Your going to need more watts. Unless you are only soldering small wires and bullets. Move up to something more like 80 watts or more. Personally I err on the side of more watts is better. You could get a 300/450 soldering gun and have all the wattage required but you would still need a smaller pencil tip iron for small soldering jobs like JST connectors or such.
Myself, I like a chisel tipped propane torch for big wire/big bullets. The job is done fast and you have no doubt the soldering is thorough. And for smaller wires/connectors I have a 25 watt pencil. There is no soldering job I cannot get done. Buy yourself some soldering flux and always have a roll of 60/40 around. Its one supply you will require thru out you RC'n day's!
JohnChange is the one Constant
I use that soldering Iron, works fine for me, but for bigger jobs I use a propane torch.
Thanks for the reply's I greatly appreciate it. I should have mentioned the I need a pencil to solder my new EC5 connectors to my esc/battery's. Any links for a good quality soldering pencil would be appreciated as well. TIAOne run at a time. Then pick up the pieces.
I recently changed all my plugs to 5.5mm. I used the Weller WPS18MP. It was like $27 at Home Depot, and it worked perfectly for the job. I used a small propane torch for the heat shrink wrap.
The Weller is very comfortable to work with and heats up very quickly, it's been pretty good so far.SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
The 40 watt Weller with the 1/4" chisel tip is excellent, maybe even overkill for 5.5's. Runs about $18...I let the dogs out...
