Sworfish 120A problem
  • carlcisneros
    • Jan 2010
    • 1237
    Just got in a 120A and it will not program properly.
    What i got is:
    Setting up throttle position (Futaba) all I get is a momentary green light on the esc's circuit board. Zero (0) volts going to the motor. No motor movement at all. Once in a while I get a momentary red light on the circuit board and an occasional little movement of the motor itself.
    Tried settingparameters with the program board, but got the same results.
    Any suggestions or information I might have over looked?
    thanks in advance
    Carl
    almost forgot, I get no beeps at all from the motor.
    I have gone thru the instructions till I was ready to chuck it across the garage.
  • britscoot
    • 721
    Some esc's require you to set your tx to reverse on the throttle.
    My swordfish 120 doesnt beep either.
    • carlcisneros
      • Jan 2010
      • 1237
      I tried that as well.
      It did the same thing. nothing
      getting frustrated.
      how do you know if the trigger on the transmitter is set correctly?
      Carl
      I even tried a different manufacturers radio and it did the same thing. nothing and no voltage going to the motor.
      all i get is an occasional green light on the circuit board when i connect power to the ESC
      • keithbradley
        • 3671
        Are you plugging the esc in with the transmitter in the full throttle position?
        www.keithbradleyboats.com
        • carlcisneros
          • Jan 2010
          • 1237
          sure am
          it is turned on as well
          even tried another radio system
          did the same thing nothing :-(
          • keithbradley
            • 3671
            Hmm...Can you tell if it's powering the receiver?
            • carlcisneros
              • Jan 2010
              • 1237
              it sure is
              but nothing out the other side of the esc according to my digit volt meter
              could the timing be off
              or motor start set too soft?
              • keithbradley
                • 3671
                I might try pulling out the pin to the red wire and putting an rx pack on the receiver. Mine did some funny stuff the other day and I bypassed the bec and it worked fine.
                • carlcisneros
                  • Jan 2010
                  • 1237
                  Britscoot;
                  if yours did not beep, how did you set up the throttle trigger on the trans mitter?
                  Carl
                  • Chilli
                    • 3204
                    Carl, was just going over the manual. Just want to verify you did have braking "turned on" on your transmitter and you were pushing the throttle forward and not pulling it back when powering up the ESC.
                    Mike Chirillo
                    www.capitolrcmodelboats.com
                    • carlcisneros
                      • Jan 2010
                      • 1237
                      braking turned off
                      it states to go to high throttle when turning the transmitter on.
                      Carl
                      • Chilli
                        • 3204
                        "Put the throttle to the forward full position, turn on the transmitter"
                        Could be worded a little better.
                        Did you say on the phone that you had your end point adjustment for full thottle at greater than 100%? If so try backing down to 100. You never know.
                        We'll play with it next Saturday.
                        Mike Chirillo
                        • Jeepers
                          • May 2007
                          • 2050
                          hmmm my swordfish beeps the motor when powering up to calibrate the tx.
                          • carlcisneros
                            • Jan 2010
                            • 1237
                            Jeepers, mine does not do it.
                            Carl
                            • Jeepers
                              • May 2007
                              • 2050
                              let me see if i can come up with some ideas for you. I am not too familiar with them. while they have performed decent I have not used them to much mostly as test units.
