Prop pitch and power
  • BHChieftain
    Fast Electric Addict
    • 2051
    Hi,
    I *think* I know the answer to this question... but I'm curious--
    Is there any condition where a prop with a lower total pitch would pull more amps than a prop with higher pitch? I know that it is possible to get more speed out of a lower pitch prop if it hits the rpm sweet spot, but what about overall power (and therefore heat) load?
    For example, I'm running a kinda dull x442 prop on a fastech on lipos and my esc to motor connectors (6mm bullets) are getting too hot-- is there any chance a really sharp/thinned x642 prop would run any cooler?? I wouldn't think so but...
    Chief
  • Flying Scotsman
    Fast Electric Adict!
    • 5195
    The answer is no if both props are ballanced and sharpened... the X642 will demand more from the power system all other things being equal.
    Douggie
      The answer is yes - maybe. If the higher pitch prop gets the hull moving faster so that it is higher out of the water with less resistance, then the motor rpm can be higher - meaning lower a amp draw. This is not common but it is seen and reported with certain setups - I have seen it on occasion myself.
      For example, recently the Insane FE-30 with UL-1 motor has been reported by several owners to run cooler on larger props. This seems counter-intuitive, but it makes sense if you think about the boat speed relative to motor rpm. Just don't assume that it will always happen - it will not.
      • BHChieftain
        • 2051
        Thanks Fluid!
        I have noticed that the Fastech on x442 does ride rather wet... I've played with the strut angle to get her out of the water a bit more, but I've hit the limit on that. I've been reluctant to try the x642 since x442 was running rather warm, but I'll give it a go and see what happens.
        Chief
        • ENCORE MAN
          • Jan 2010
          • 1096
          I recall a response by Darrin reminding us the FASTECH prop is not a surface drive prop and the handling and temps would be affected by over propping. I followed his advice and ran x438 and x440 props and found I could get around the course just as quick but with lower temps all round. BG
