JAE FE LiPo Compartment
  • JRS Innovations
    • Oct 2010
    • 169
    I am waiting for my JAE FE to come back from being built.
    Does anyone who owns one know if a 5000 4S 40C LiPo
    with the dimensions of 138 x 45 x 46mm fit ok.
    Thanks
    Joe
  • teach
    • 509
    Yes. Get back to doing nothing.
    • teach
      • 509
      BTW did you post your UL-1 stands in the unique products section?
      • weil0127
        • Dec 2009
        • 200
        Yes they are there.
        www.namba20.com
        • weil0127
          • Dec 2009
          • 200
          Found these here on OSE.
          http://forums.offshoreelectrics.com/...0&d=1286857352
          http://forums.offshoreelectrics.com/...3&d=1286725900
          www.namba20.com
          • Chilli
            • 3204
            Width of the tub deck opening is usually the limiting factor. I measured it at 48mm so you should be good. My 45C Hyperions fit no problem. My cheapo Turnigys are a snug fit.
            Mike Chirillo
            www.capitolrcmodelboats.com
            • Steven Vaccaro
              Administrator
              • 8932
              Is that the norm for the interior layout? Anyone else have any other interior pictures?
              Steven Vaccaro
              • Chilli
                • 3204
                The layout is pretty much standard. Battery goes between the rear bulkhead and rear boom. ESC goes in front of the boom. ESC motor wires are extended a few inches. Doug Smock installs a false floor that the battery sits on and runs the wires and cooling tube underneath. I just lay the wires over the top of battery. First pic is the business end of my boat. Second pic is Doug's battery/ESC layout.
                Mike Chirillo
                • JRS Innovations
                  • Oct 2010
                  • 169
                  Thanks
                  Tino, Joe, Steve & Mike.
                  This is a great FE Forum for a Rookie like me....Awesome
                  Joe
                  • Chilli
                    • 3204
                    And we bahave allot better than on Jim's. LOL
                    Mike Chirillo
                    • m4a1usr
                      Fast Electric Addict
                      • 2036
                      Whoa! Those are some LONG esc/motor wires.
                      John
                      Change is the one Constant
                      • Doug Smock
                        • 5359
                        John
                        John it works perfect when you're not pulling 80 to100 amps with your "limited" setup. lol
                        We have several of these running and they are doing well. Nothing is hurting and the guys will tell you they run great.
                        There was 2" of wire added to the motor leads. 4" of that came from the battery leads so technically we only added 2'' to the setup, none if you consider the loss of the series jumper that was originally wired to the control.
                        I really like the way it cleaned up the set ups, not that there is anything wrong with what my bud Chilli did.
                        Doug
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • JRS Innovations
                          • Oct 2010
                          • 169
                          Doug
                          Hello John
                          So bear with me here cause I am a rookie.
                          So when you say "Limited set up" are you refering to like a P-Spec set up with a UL1
                          motor & speed controller.
                          Also I am thinking I would like to put (2) 2S packs instead of (1) 4S pack
                          so as to not have so many style packs.
                          It seams to me that 2S packs will be much better for placement flexability
                          within other hull set ups that I want to get.
                          Any info on that theory of mine taking into account my lack of knowledge
                          would be helpful.
                          Thanks
                          Joe
                          • MaxCorvette
                            • Feb 2010
                            • 12
                            Here is mine...
                            Esc is beside the lipo pack, for shortest wires possible..
                            Marcel
                            • BakedMopar
                              No Mo Slipah
                              • Sep 2009
                              • 1743
                              I use a sub floor like D.smock. I use both 2s and 4s in my rig. The 4s really cleans up all the wires. I too added extra lenght for the motor leads and found noting wrong with it. These are awesome hulls and becomes boring on how well they run.
