The price on these has dropped to $45.26 if anyone is interested.
Himodel 200A ESC Price drop.
If I remember correctly, youve run these and been quite pleased havent you?
There are many on the market now that are the water-cooled version. I bought a couple Sky-wings but have to try them out.
I am interested, how do you program them?Originally posted by FighterCat57Guys, I have 20 of these 200a ESC's coming direct from Suppo. Hold on a bit and I'll cut most of them loose at a great deal and only keep what I need. I can also give them a good conformal coating as well as fit them with a cooling block, ready to go.
They are en-route, so should have them by this coming weekend. I'm in FL, so 2-3 days to anywhere in the US. =)
I'll post up more info when they arrive. I just couldn't resist doing some research on these.
Glad to see you are doing this. I also bought a bunch of them to experiment with, you can check previous posts, and had good success. They are indeed a good disposable ESC. Like you plan I added cooling blocks, larger caps,new heat sink material, re-routed the wiring and conformal coated. In addition I hard mounted via thermal epoxy, Eagle temp sensors both on the caps and within the FETS. I certainly leaned a lot from a rather small expendature. Good luck.Originally posted by FighterCat57Yep. 6s and no warranty. Great for disposable experimentation.
I want to experiment with some thermal compounds and didn't feel like dealing with HiModel, so I asked my LHS to order a batch for me with water cooling blocks direct from Suppo.
Since I have Capacitors, Resistors and Coatings, I plan to set some up for testing and let the rest go. I'll post up details when they arrive. Until then I can't promise or hold any.
They are programmable by Tx. (see attached)
I must be honest, why do you guys screw around with really cheap esc's and the possible damage they may cause, just my 1/2 cent and believe me I like a bargain.
Douggie
Anxious to hear your test results. Can you bottom water cool on a hydro or cat?Originally posted by FighterCat57Right on. I've found a thermal epoxy mix that is quite inexpensive, so the plan is to make a mold and mold a few of them in this epoxy mix with water tubes running through them. Some directly mounted to aluminum plates countersunk in to the bottom of the hull. Direct water contact at all times. If it works well with the cheap ESC's then maybe apply that process to a good expensive one and hopefully end up with a solid setup that is predictable.
Who knows, if the MFR approves of this process, perhaps they will start molding marine ESC's that are truly water proof and have excellent heat dissipation properties.
I know... a bit of dreaming. But fun non-the-less.
Had Tony and Brad run some FE's at my lake yesterday. Interesting that Brad had a HiModel 200 he added a heat-shrink cooling plate. Unfortunately he was running a really hot set up with Castle 1515, 2300KV motor on 6S that was proped wrong and running real wet. It lasted about a lap or so before his hull inside was graced wit that all to famaliar smell. Tony measured the temp of the ESC at 230F, so hot it burnt the power wires off the solder joints. Pics show the ESC post run. The cooling was not nearly good enough and I guess there was well over 200 Amps running thru it. I wonder if your poured thermal epoxy ideal would have survived? Circulating a cooled non conductive fluid line chilled mineral oil, directly thru the FETs may have been the only way to get out this massive amount of heat.
Originally posted by FighterCat57Yeah a cooling block just won't cool that ESC enough. That hot setup didn't help either!!
The parts are on the way, I'll keep you guys posted in this thread. No need for PM's.. just subscribe here.
I am in for one please!
RobertDJI Drone Advanced Pilot
Canada
Albert
