Fast Electric Main Forum
flex shaft replacement question.
britscoot
Jul 2010
10-02-2010, 08:42 AM
is it possible to remove the flex from the hard shaft?
If so how do you do it?
thanks
ENCORE MAN
Jan 2010
10-02-2010, 08:54 AM
Originally posted by
britscoot
View Post
thanks
Quick and easy,,,,propane torch set on lowest setting. Heat prop shaft end until solder melts and remove flex cable. BG
britscoot
Jul 2010
10-02-2010, 09:06 AM
Thanks!
what kind of solder do i need for rebuild?
i really appreciate the help.
ENCORE MAN
Jan 2010
10-02-2010, 09:46 AM
britscoot
View Post
Thanks!
I use 60 /40 solder from Radio Shack, It works for me and can withstand a little heat. BG
