Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 HOPF CNC Aluminium Props 3 blades ?? - RcBoaters Forum
  • Alfa Spirit
    • 2183
    Do you know those propellers? They are belanced just need to be sharpened
    A set of 42mm DD for twin looks great and not very expensive
  • video200
    • 840
    how wil the aluminum hold up with the rpm`s ?
    just have notised that when i run my mhz aluminum prop (29 1,4) on my micro drifter it is noticeable slower then when it run it with a octura 427.
    • Alfa Spirit
      • 2183
      I don' t think Prather S propellers work fine, No advice about Hopf/Tenshock props?
        • 9481
        They look sweet!
        • Alfa Spirit
          • 2183
          Nobody use those propellers? 4 size are available 38mm 40mm 42mm and 45mm diameter, pitch = 1,4
          • blackcat26
            High Speed Junkie
            • Sep 2009
            • 1750
            I have been wondering about these also. My plan was to rig em up with a .188 hole so I could actually use them first......
            • Alfa Spirit
              • 2183
              2 versions are available M4 and DD 3/16"
              • blackcat26
                High Speed Junkie
                • Sep 2009
                • 1750
                Cool. I was wondering if they would deform under high rpms also
                • electric
                  • 1973
                  Alfa, could you translate for me, which ones are for the 3/16? Couldn't figure it out.
                  • Jesse J
                    scale FE enthusiast
                    • 7818
                    I have two in my cart... As for deformation, I think there will be much less force on each prop when run in twin set ups. I don't foresee much deformation and am really tempted to pull the trigger - my twin Triton has that look, "what, I don't deserve em?"
                    "Look good doin' it"
                    See the fleet
                    • electric
                      • 1973
                      Is the one that says Drive Dog the correct specification for 3/16?
                      Aufnahme :
                      M4
                      Drive Dog
                      The shipping looks like it is 25 euro?
                      • Gerwin Brommer
                        • Dec 2008
                        • 928
                        Yep, DD = 3/16 th
                        Shipping is 25 euro
                        BUT : why on earth is the prop balanced but NOT sharpened ??
                        if you sharpen in yourself, the balance is gone !
                        • Alfa Spirit
                          • 2183
                          You can choose the language
                          I put an order for 2 props 42mm one right + one left = 85US$
                          • Ub Hauled
                            • Aug 2007
                            • 3051
                            exactly what Gerwin said... CNC props should be sharpened as well... they are made so you can plug n play.
                            I bought some from a local vendor which would be better in your case and cheaper as well...
