0.150" vs. 0.187" flex
  • Insaniac
    • 496
    At what point should you switch from 0.150" to 0.187" flex drive? I'm running 0.150" flex with Teflon liner for P-spec motor but plan to go to something more potent in a hydro.
    Does everyone run Teflon liners? Why or why not?
    Has anyone broken a 0.150" flex?
    Support US hobby suppliers
  • steveo
    • 1595
    i think with out is alttle more free to me at least i am using a .187 with about a 16" cable with minimal bend in a cat and it feels smooth
      The 0.150" is fine for spec power, but for anything more potent I use the 0.187" (or 0.25" for 10S). The friction/drag difference is small while the strength difference is large - the 0.187" is 55% stronger.
      I haven't used a Teflon liner in many years, even swapped it out in my UL-1 for straight brass. If a good lube is used there is less friction with a bare brass stuffing tube than there is with a Teflon liner - tests prove it. This is because the Teflon deforms and has a much greater contact area with the cable than the hard brass does. Too, the Teflon wears out, shreds, grabs the cable and breaks it. This has never happened with brass IME.
      I have yet to wear out a brass stuffing tube either, even though some boats have been raced three heats a day, twice a month for over several years. The trick is to use a good quality EP (Extreme Pressure) lube, this cuts friction immensely. With a brass sleeve bushing in the strut and the good lube I have yet to wear out a sleeve either. More drag, shorter life, and you still have to lube the Teflon liner - so where is the advantage?
      • steveo
        • 1595
        fluid can you tell me what lube you use and where to get it
          Pennzoil Synthetic Gear Lubricant (SAE75W90 GL-5)
          There is no magic in that particular brand; I bought a quart five years ago at WalMart for $4 and it's still half-full. Other brands may work just as well, the important component is the extreme pressure additive (check the label carefully).
          Part of my core business is spinning one loose-fitting steel pipe inside another. The pair often make 90 degree changes in direction, and lubricants are important. The lube listed above works well in high load friction testing, and even when emulsified with water it still provides excellent metal-on-metal lubricity.
          Are there better cable lubes? Maybe, I've only tested a few. But I also know a few which are popular yet don't work particularly well at reducing cable friction.....
          • LuckyDuc
            Team Ducati Racing
            • Dec 2008
            • 1058
            I run a 3/16 cable in my P limited, P Sport, and P mono with no Teflon liner as well. I have broken a .150 cable when the Teflon liner wrapped itself around the cable. I stopped using liners after that.
            • Jeff Wohlt
              • 2740
              Dollar General Motor honey for oil burning motors. Like STP but $1. I use this crap for threading couplers, drilling stubs and love it.
              Another good option is Chain Saw bar lube....extreme heat and rpm and sticks. One gallon is good for 57 years running everyday...LOL.
              www.rcraceboat.com
              jwohlt5362@yahoo.com
              • steveo
                • 1595
                alittle of topic but were taking lube can someone give what type to use in motor bearing, is there a high speed something i should use
                • Jeff Wohlt
                  • 2740
                  I use Trinity bearing lube in a needle dropper that comes on it. Seems to be good stuff. One drop is all you need.
                  Boca makes some good stuff but not sure what it is.
                  www.rcraceboat.com
                  • Gary
                    • Jan 2009
                    • 1104
                    What do you guys run with a .187 cable a 7/32 tube or larger for no stuffing tube liner.
                    H&M 1/8 Miss Bud 73 mph
                    Chris Craft 16 mph
                    • Jeepers
                      • May 2007
                      • 2050
                      I run the 1/4 tube with no liner with the .187 cable seems to work fine. I tried the 7/32 with the .187 cable stuffing tube got really hot after a run.
                      • BakedMopar
                        No Mo Slipah
                        • Sep 2009
                        • 1743
                        My hydro was like that with a 7/32" and it got hot enough to smoke the lube. I use 3/16" in 1/4" no teflon in all my boats except my spec rigger which is .150" with no liner.
                        • LuckyDuc
                          Team Ducati Racing
                          • Dec 2008
                          • 1058
                          I fiber glass a piece of 5/16" tube in the hull and then slide 1/4" tube through that for the stuffing box. This allows you to replace the stuffing box without cutting it out of the boat.
                            I've done the same thing on all my boats.....except that I have never had to replace a brass tube. It is also handy for pulling out the stuffing tube and making careful bends in it to adjust the strut.
                            • Insaniac
                              • 496
                              Thanks for the great input. I was ready to pull the 1/4" stuffing tube in my hydro and replace it with 7/32", but it sounds like I am better off using the 1/4" with the 0.187" flex.
