cap bank
  • steve-b
    • Mar 2010
    • 274
    cap bank
    Hey guys,
    Has anyone out their built their own cap bank?
    Can you tell me how to do it... Maybe a drawing.
    Thanks,
    Steve.
  • longballlumber
    • 3417
    You don't need to build a "bank" as long as you know what specs you want just buy one cap.
    This place has 3 different ones to choose from...
    You can find others at www.newark.com
    Later,
    Mike
    • steve-b
      • Mar 2010
      • 274
      Isn't running more smaller caps in parallel better at dissipating heat. Rather then using one large one?
      • BakedMopar
        No Mo Slipah
        • Sep 2009
        • 1743
        Check out post #60 on me thread.
        http://forums.offshoreelectrics.com/...t=13980&page=2
        • steve-b
          • Mar 2010
          • 274
          Ive been doing some research on-line.
          I'm going to make one using 35A 470uF caps that i can get locally for $0.35 each.
          I'm going to make a PCB using cool software that i downloaded. the copper plate, and chemicals are available from the same local vendor. Id rather not use the "perf board"
          Ill post some pics when its done. Not sure when that will be.
          Thanks for the input.
          Steve.
          • jimbo--jones
            • Jan 2010
            • 58
            make sure the caps are rubycon or similar low esr
            • bonewar
              • 587
              Originally posted by steve-b View Post
              Hey guys,
              Thanks,
              Steve.
              Steve,
              This is how i added the extra caps to my Hydra 240HV ESC.
              I think the pictures tell the tail.
              And water cooled .
              Bonewar
              SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
              • Alexgar
                • Aug 2009
                • 3701
                radio shack has some larger ones reasonablly priced
                • m4a1usr
                  Fast Electric Addict
                  • 2036
                  Absolutely. Do not run the standard mill or normal commercial off the shelf caps. They are not rated for the operating freq. we need in our speedos. The reason you need to use ultra low esr caps is because as frequency or switching increases so does the internal resistance of the cap.
                  Thats why they get hot. As resistance increases they actually consume some battery energy. But its only waste heat. Thats why we use low or ultra low esr caps. They dont get as hot over time. Use a cheapie and you just increased your chances of popping one or worse.
                  John
                  Change is the one Constant
                  • steve-b
                    • Mar 2010
                    • 274
                    I just got back from A1 electronics, its a really cool store in toronto.
                    I piked up a pile of 35v 470uF low esr caps. I also got a couple of pcb's.
                    Should have one built within a couple of days, just need to get some ferric chloride. Should be their on Wed.
                    Ill post some pics when i get one finished.
                    • steve-b
                      • Mar 2010
                      • 274
                      Hey guys.
                      heres a couple of pics of what the circuit will look like.
                      • CornelP
                        • 793
                        I would do those lines as thick as physically possible... I burnt one like this. There's also less to corrode.
