watercooling issues
  • Woodz
    • 42
    watercooling issues
    forgot to put this on my last post but my 25"hor rocket has a watercolled motor and esc and they dont seem to get any water it uses a water pickup on the rudder???
  • sailr
    • 7128
    Take the line off the top of the rudder and blow through it. If you can't, there is a blockage somewhere. What's with the T fittings? The way you have it set up the water is blowing right past the motor and out the discharge! Get rid of those "T's"! Run from rudder through esc to motor, through motor and out! Period!
    Mini Cat Racing USA
    www.minicatracingusa.com
    • Diesel6401
      Memento Vivere
      • 4391
      Water takes the easiest route so with that being said all the "t" connectors you have maybe part of your issue. Get rid of those connectors and run the water line to the esc 1st then to the motor or mount then motor. Just have cooling to the esc first. Take a small rat or round file and slightly enlarge the opening in the rudder. First step is to dump those connectors though. Take the cooling line off the top of the rudder and blow through it make sure you feel air coming threw the outlet.
      HAHAHA SAILR YOU POSTED WHILE I WAS TYPING.
      - Diesel's Youtube
      - Diesel's Fleet
      • sailr
        • 7128
        Great minds think alike! LOL
        Mini Cat Racing USA
        • Diegoboy
          • Mar 2007
          • 7444
          Start by eliminating those "T" joints.
          Route it as such: Pickup to ESC - ESC to Motor - Motor to outlet
          Post a pic of the opening in the rudder blade please...
          • Diesel6401
            Memento Vivere
            • 4391
            I don't know about me having a great mind, but thanks.
            Originally posted by Woodz
            yh soz i posted wrong pictue it doesent have tht t connector now it goes just like u both said through the esc then motor and theres NO blockage in the rudder ???
            Take off the hose at the top of the rudder and enlarge the rudder pickup with a small round file and blow of the shavings. Don't blow out the shaving with the hose attached because small pieces of debris can get blown into the line causing a blockage later.
            - Diesel's Youtube
            - Diesel's Fleet
            • Woodz
              • 42
              yh ok ill try tht?
              • scoota
                FE DOWN UNDER
                • Dec 2008
                • 439
                Try the T-pieces this way it looks like you dont have them flowing the right way
                UL1- 1515 castle/neu / 240 swordfish
                SV27- with UL1 running gear
                33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
                • sailr
                  • 7128
                  You don't need the T's at all! Get rid of them! Take off the tubing from the rudder and blow through it! Is it clear? I wouldn't booger up that rudder! Most likely the opening's fine. I have NEVER had to enlarge one.
                  Mini Cat Racing USA
                  • Woodz
                    • 42
                    reply
                    i feel like my water cooling still wont work would it help if i primed the system with a mouth full of water then used it????
                    • sailr
                      • 7128
                      You never answered whether or not you can blow through the system? If not, then there is a blockage. If you can, then it should be working. Why do you say it's not working? Have you run the boat?
                      Mini Cat Racing USA
