Prop???
  • steve-b
    • Mar 2010
    • 274
    Prop???
    Hey guys,
    Just thinking about running a matrix rigger witha a 3s2p setup, the motor is a 1512 1.5d
    My question is, can anybody suggest a prop for this?
    I have never ran a 3s setup before, Im guessing around 32- 36mm ???
    Any help would be great.
    I did look it up on a prop chart, but thought i could get some real world feedback.
    Thanks,
    Steve.
  • steve-b
    • Mar 2010
    • 274
    nothing ?
    • m4a1usr
      Fast Electric Addict
      • 2036
      I've seen that hull run on a 637 and another with a 440/3. That Neu will turn alot of prop so dont go crazy. I bet it could spin a 642 and not burn anything up. What speedo and size batts are you going to be using?
      John
      Change is the one Constant
      • steve-b
        • Mar 2010
        • 274
        I am using a hk 180 Esc,and i will be using 4000 3s 40c batteries.
        • nobbiworld
          • 170
          I have only run this motor on 4s1p. In a HOTR 32 inch cat had a 438 on it. Around 60 mph. Went well with no heat problems. In a 32 inch mono with a gear box 1.6 to 1 on 4s1p, have been as big as a 445. Had a 442 on and set the fastest heat time at the Aust nationals. Speed control was a 150 Etti and a seaking 180. Both had no issuses. You just have to let it rev, dont load it up.
