please help me with my boat i want MORE speed
  • Woodz
    • 42
    #31
    reply
    yh t was awsome the only thing is i use 4 stinger and i find it hard to find good props and my temps werent to hight couldnt rely tell only ran it for 3-5mins wat props would u think?
    • Diesel6401
      Memento Vivere
      • 4391
      #32
      3-5 minutes is perfect run time. That's what you should aim for all the time. Something in the 37mm range would work fine. Mid 30's in the boat isn't bad at all. What exact motor are you using again?
      - Diesel's Youtube
      - Diesel's Fleet
      • Woodz
        • 42
        #33
        reply
        im using a 2300kv 540 and ive got a 35mm 2blade prop already?
        • Diesel6401
          Memento Vivere
          • 4391
          #34
          Is that a 540s, 540l or 540xl?
          - Diesel's Youtube
          - Diesel's Fleet
          • Woodz
            • 42
            #35
            i think its standard this is my motor http://www.giantcod.co.uk/black-mant...-p-403775.html
            • Diesel6401
              Memento Vivere
              • 4391
              #36
              Yea you should be able to prop up no problem. Try a 37mm prop check the temps then you maybe even able to try a 40mm prop.
              - Diesel's Youtube
              - Diesel's Fleet
              • Woodz
                • 42
                #37
                does it matter wat make should i go for a octura with a sleeve maybe a 440
                • Diesel6401
                  Memento Vivere
                  • 4391
                  #38
                  What size drive shaft do you have? 4mm, 1/8 or 3/16?
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • Woodz
                    • 42
                    #39
                    4mm know i can use a 3/16 but with a bushing?
                    • Basstronics
                      • 2384
                      #40
                      How are you measuring the speed? Do you have GPS?
                      I run a 42mm prop- BUT it doesnt have a lot of pitch. I think its a 42 1.4P or some crap like that.
                      4mm shaft.
                      I need to find some props to try. I have Eagle Tree. Also reworking my boat now. Hopefully on the water Sunday.
                      • Woodz
                        • 42
                        #41
                        i use a gps on my htc desire how fast does ures go on tht prop
                        • Basstronics
                          • 2384
                          #42
                          Ha, I hope you never loose your boat or phone.
                          I just got the eagle tree so Im not sure. The boats been torn down since getting it. Will know more soon.
                          If i had to guess- I would say 35-40 mph. But its a guess. Im going up in motor now too... so we shall see.
