43-44 mpg Tops
  • dtacmed
    • Mar 2008
    • 215
    43-44 mpg Tops
    Ran my 33" Mono (DF Clone) all weekend. setup 13 XL Feigao, X645 and X445. 1P6S (2) 3 cell in series. Venom 5000 35C and Protek 4200 45C. Adjusted prop angle. (Fullers Mono Hardware) running solid 43and 44 mph also running etti 150 with cap bank. Was hoping for a little more but guess with this setup thats about it. What do you think?. Video Attached
  • Rumdog
    • 6667
    how are your temps?
    • dtacmed
      • Mar 2008
      • 215
      140s but water temp is still very warm here in NC.
      • RIPFENCE
        • Sep 2009
        • 1577
        venom lipos have been sort of notorious for not putting out the advertised discharge rates..i do not know about the protek ones..this may be costing a few mph..i would think that setup should at least be in the high forties though..
        "FE" STANDS FOR FRUSTRATING EXPLOSIONS
        • Rumdog
          • 6667
          Are you running two different brands of lipo in series?
          • dtacmed
            • Mar 2008
            • 215
            I have 2 sets 1 set of Venom 5000 35 C and 1 set of Protek 4200 45C I'm not mixing. I'm either running the Venoms or the Proteks
            • dtacmed
              • Mar 2008
              • 215
              The Proteks seem to have more punch but speeds are staying pretty much the same with either set
              • dtacmed
                • Mar 2008
                • 215
                Video of last run of the day
                • RIPFENCE
                  • Sep 2009
                  • 1577
                  Looks to be running smooth maybe a little on the wet side...did you try adjusting your prop thrust angle a little more until it was running loose? I know i can get my monos dialed after raising the angle too high and then lowering down from that point..even if it gets loose then you can play with the position of your batteries and move them forward to keep the nose down....maybe get you a couple more mph..
                  • dtacmed
                    • Mar 2008
                    • 215
                    Yea I adjusted untill it was pretty loose. May have gained a little more speed but not worth the handling.
                    • Rumdog
                      • 6667
                      It all depends on what you're willing to pay for the extra speed. A Castle/Neu 1520 will have you flying with that hull.
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        Mid 40's is about what you can wring out of a Feigao XL in a 33" mono............
                        Like your thread title..............43-44 miles per gallon..............
                        • RIPFENCE
                          • Sep 2009
                          • 1577
                          SPEED COSTS A LOT ESPECIALLY IN BOATS..YOUR SPEED IS RESPECTABLE WITH THAT SETUP THOUGH.THE HANDLING IS GREAT
                          • dtacmed
                            • Mar 2008
                            • 215
                            Thanks thats kinda what I expected to hear. Really satisfied with how it is running and handling. Just wanted to make sure I was getting all I could out of that setup. Thanks again, the information provided here is great and really helps us new guys.
                            • video200
                              • 840
                              you should se a few more mph with the X645 prop over the X445 but it wil use more amps
