esc for Leopard 4074(2000kv)
  • ezhitz
    • Aug 2009
    • 466
    As title says what esc is recomended for that motor running in a 30" scale on 4s
    120amp or should i go 180amp ?
    thanks
    :canada
  • Rumdog
    • 6667
    180 is a much safer bet. They can/will pull a lot of amps. What is the hull?
    • ezhitz
      • Aug 2009
      • 466
      It's in an osbourne Miss Supertest wooden kit.
      :canada
      • Rumdog
        • 6667
        That's gonna be one fast shovel! If it were me, I'd def. go with the 180.
        Hi-Model may have some in stock
        • ezhitz
          • Aug 2009
          • 466
          thanks
          :canada
          • RCKong
            • Sep 2009
            • 1680
            Yep, the T180 works very well with my 4074 2200kv leopard motor on 4s
            • CornelP
              • 793
              +1 for the T180, it is barely warm after a 6min race on a 30" mono with a X442.
              • NOZ69R
                • Apr 2010
                • 42
                for hijacking
                I've just got the same combo Hi-Model Seaking 180 & Leopard 4074 2000kv and would like to know what timing I should set the ESC at.
                Its in an Apparition running 4S.
                Another question, what prop should I be running.
                Cheers
                NOZ
                The older I get the BETTER I was..
                • CornelP
                  • 793
                  I have the same combo on my intruder, I run medium timing and a X442 prop. It is a decent starting point.
                  • NOZ69R
                    • Apr 2010
                    • 42
                    Thanks CornelP
                    I'll give that a go.
                    Cheers
