whats the best way to cut 2.5mm carbon sheet?
  • britscoot
    • 721
    Looking for some good advise on working with carbon sheet.
    What do you guys use for cutting it?
    Thanks much!
  • domp444
    • Jul 2009
    • 901
    I'd like to know as well :)
    • Rumdog
      • 6667
      a bandsaw and face mask. Gloves and safety glasses too.
      • egneg
        • 4759
        It's a real PITA! I have a dremel 4" saw with a carbide blade so the basic shape was not much trouble. But to drill holes and cut outs for servos is another story. I went through 4 drill bits and half a dozen scroll saw blades to drill four holes and do the cut out for the servo in my Gen 2 Skunk Cat.
        P.S. I used a 1" belt sander to round the corners.
        IMPBA 20481S D-12
        • egneg
          • 4759
          I almost forgot about the fibers that itch much worse than fiberglass.
          IMPBA 20481S D-12
          • domp444
            • Jul 2009
            • 901
            This sounds like a lot of work to make just some small parts I wanted. I was gonna get the dremel in hopes that I could just cut it, haha. Thanks for the info! I'll look into either making them myself or asking someone else to
            • egneg
              • 4759
              It looks great but next time I will use wood.
              IMPBA 20481S D-12
              • domp444
                • Jul 2009
                • 901
                • ScarabChris
                  • Oct 2010
                  • 812
                  I'm currently working with 3mm thick CF board and I cut it on my table saw using a regular wood blade. The cuts were as smooth as if a laser cut them.
                  • egneg
                    • 4759
                    Does the blade have carbide tips? My 4" saw does and it was no problem but HSS will not hold up.
                    IMPBA 20481S D-12
                    • ScarabChris
                      • Oct 2010
                      • 812
                      Yes, its a 10" blade and I do believe it has carbide tips. It cut like a hot knife through butter.
                      • Gerwin Brommer
                        • Dec 2008
                        • 928
                        jigsaw and a blade for cutting ceramic tiles ( like bathroomtiles ), that works fine.
                        like ; http://www.priceinspector.co.uk/c/40...compare-prices
                        • blackcat26
                          High Speed Junkie
                          • Sep 2009
                          • 1750
                          Gerwin has the ticket! I have used my wet tile saw with a diamond bade with great results. The water keeps the dust down as well. On a tile saw like mine intricate shapes are out but great for battery trays!
                          • ron1950
                            • 3082
                            great ill send you guys all my cf to cut lol...
                            • domp444
                              • Jul 2009
                              • 901
                              Haha, that's my next idea!
