antennas
  • britscoot
    • 656
    antennas
    After checking out a lot of pictures on this site,i've noticed quite a few boats without antenna tubes.
    How are you guys running antennas?
    Cheers
    Ian
  • Diesel6401
    Memento Vivere
    • 4203
    Cheers
    Ian
    With the new 2.4ghz radios some systems antenna's are not used. i.e the tactic/tower systems don't have an antenna on the rx. Check it out http://www3.towerhobbies.com/cgi-bin...?&I=LXWJN2&P=7. Very cost effecitive nice simple radio and no antenna. I use the tatic radio and just just buy extra rx's but I also do have a dx3s which rx's do require an antenna to run out the hull. I like the fact the tactic has no antenna but i like all the bells and whistles the dx3s has, just wish spektrum had a no antenna rx.
    - Diesel's Youtube
    - Diesel's Fleet
    • britscoot
      • 656
      Thanks for the reply!
      i have the spektrum marine rx also and hate the fact i have to run 2 antennas!
      Guess i've gotta drill a hole in my new hull......boo!
      cheers
      Ian
      • Diesel6401
        Memento Vivere
        • 4203
        cheers
        Ian
        I assume your refereing to the mr200 rx? What I did with mine was take the longer of the 2 and run it out the hull, neatly rolled the second one up and used a twist tie to keep it from unravling and just tucked it away inside the hull. Only 1 of the 2 need to be outside the hull.
        - Diesel's Youtube
        - Diesel's Fleet
        • britscoot
          • 656
          yeah,only the long one out of the hull.
          I run and tape the small one up under the deck.
          Wish i had known about the tactic before i bought the spektrum.
          oh well
          • Diesel6401
            Memento Vivere
            • 4203
            oh well
            Which spektrum do you have? I have the DX3S and it is a far superior radio compared to my Tactic.
            - Diesel's Youtube
            - Diesel's Fleet
            • keithbradley
              • 3663
              I run spektrum inside the hull. I put velcro on the underside of my hatch (highest spot of the boat) and I take a small piece of shrink wrap (un-"shrunk") and wrap velcro (opposite kind as what I put on hatch) around it so I end up with a velcro tube. I then run teh antenna through the tube (you can put a dab of glue to hold it if you need) and stick the tube to the underside of the hatch when I put it on. Works for me
              www.keithbradleyboats.com
              • britscoot
                • 656
                I have the DX3 also.
                I like it ,but dont like antenna tubes sticking out of hull....lol
                • britscoot
                  • 656
                  i like it Keith!!!
                  Will test it out this weekend.
                  Thanks
                  • Diesel6401
                    Memento Vivere
                    • 4203
                    I agree the antenna thing blow. If I by a RTR or China boat that has a slot for the antenna already cut out I use my DX3s, If I buy a clean hull and don't want any antenna I buy another tatic rx. For only $20 it's hard to beat
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • Flying Scotsman
                      Fast Electric Adict!
                      • Jun 2007
                      • 5190
                      I stewed over this question for about a month ...have a Tactic and a Hitec FM ...desired new radio....purchased a DX3S with marine rx....why?....I love the design thought of two antennas and an rx designed for boat applications.
                      Douggie
                      • BHChieftain
                        Fast Electric Addict
                        • 1964
                        Some things to think about...
                        2.4ghz and H20 don't mix so well, so getting a 2.4ghz anntenna up out of the hull and away from the water will give you the most range.
                        Also, if your boat capsizes, and you use a rescue boat to haul out a fishing line, the submerged anntenna tube gives the fishing line something to wrap around...
                        Chief
