CAUTION ! : Corrosion-X is FLAMMABLE !!
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    Had to peel the shrink off my Hydra 240 to chase away some moisture [don't ask], sprayed with Corrosion-x. Dabbed some off but still had some wet spots. Plugged in battery & the SC sparked & FLAMES about 10" high in the boat. All was saved but the Hydra 240. Small print warns of this. BE CAREFULL !!!
  • SweetZ28
    • 1535
    Yea i think it's flamable when first sprayed on it has to air out for a while then i think it's ok.
    It's the prepellent that's flamable in the can so it sprays out..
    WWW.PPRSLOTS.COM
    • Rumdog
      • 6667
      Probably part of the reason that when some sc's fail, the fire is sooo bad. I had on go in my Rico a wile back. The sc was covered in corrosionx. Motor was sprayed, and I'm sure there was some overspray in the hull. Worst stinky mess ever!
