Mean machine Motor...
  • JMSCARD
    • Mar 2010
    • 4174
    So I have been running my mean machine with a 1515 1.5y for awhile now... I am thinking of turning it into a 4s boat.... and trying a leopard 4074..
    My question is weather I should go with the 2000kv motor or the 2200kv motor.... or on another note should I step up to the 4082 (1521 equivelant)?
    I run a hydra 120 in her now with no issues.... even run on 6swith a x440 prop, with the 1515 1.5y (1500kv) neu...... and would like to keep the hydra in there because my seaking/turnigy 180's don't fit well in the mean machine as I have a subhatch which makes for a tight fit...
  • Jeff Wohlt
    • 2740
    Mine is getting the 2200 and 4S and will try spinning a 545. Then 6S and around a 640 or 440
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • keithbradley
      • 3671
      I run the 2200kv 4074 on 4s with a x445 and it runs quite well. Never had any heat issues.
      I have a 4082, I think they are going to be sweet motors, but I dont think they make a kv above 1600 in the 4082 so you wouldnt be turning a lot of RPM on 4s.
      www.keithbradleyboats.com
      • JMSCARD
        • Mar 2010
        • 4174
        Yeh I was thinking stay with 6s if I went with the 4082..... obviously bigger esc then too.... but the x445 is to much prop for my setup with the 2200 I believe...
        • keithbradley
          • 3671
          I thought it would be a lot for mine, but it runs pretty cool. Just running a SF120 esc. I run it in a supervee that runs pretty dry though, you may have different results with the MM.
            • 9481
            Where the heck do you get a 4082 at?
              These guys have an interesting slection... : http://www.himodel.com/sort.php?brand=217
              • keithbradley
                • 3671
                Right now, you can get one in the OSE swap shop!
                • ls1fst98
                  • 905
                  I just picked up a UL1 motor (2030kv) to run in my mean machine. any suggestions on prop size on 4s with intentions of goin to a 5s setup with either the ul1 esc or a 120a turnigy?
                    • 9481
                    Sweet, thanks Ray
                    • DISAR
                      • 1137
                      I had exactly the same thought, to replace the 1515 1.5Y with a 4s motor so tried the Infinite 1650kv one with custom carbon cooling jacket on 4s with the 646/3 aquastar 120. it went pretty well, motor was cool and ordered also the 1860kv for a test
                      http://www.okhobby.com/product.php?id_product=1159
                      http://www.okhobby.com/product.php?id_product=1161
                      http://www.rcfastboats.com/
