Speed Guess 33-DF
  • dtacmed
    • Mar 2008
    • 215
    Here are the results.
    Protek 4200 45C x445 46.5 mph
    Venom 5000 30C X645 48.7 mph
    Feel like with the 645 and the protek it will easily run in the low 50s
    Very satisfied no adjustments on CG or prop angle on the lake. CG right at 10"
    Prop angle pretty much flat with hull. Handled like a dream
    Temps got to around 140 on the motor about 110 on the speed control and about that on the batteries. What should be my Max temps?
    Thanks again for all the info.
    • v-spec
      • Jun 2009
      • 1046
      Originally posted by v-spec View Post
      In that case I would guess maybe 47 maybe 50 just a guess. Do you have a gps for when you test it?
      I was close! I'll just pretend I was exactly right and your GPS was wrong! I think electric was closer??
      • dtacmed
        • Mar 2008
        • 215
        Yea you were right on the money. What should my max temps be?
        • v-spec
          • Jun 2009
          • 1046
          ESC and batteries seem fine. I like my motors in the 120's range along with batteries how long were you running it?
          • dtacmed
            • Mar 2008
            • 215
            around 2 mins at a time pretty much wide open.
            • keithbradley
              • 3671
              I'm going to guess cause they were used in a 30 amp truck so none were close to the maximum discharge rate of even the 20c packs. They still coulda got the same packs though. Still it's a better test than anyone else has ever done and posted results.
              I did some comparison with Venoms but I didnt want to jack his thread so I started one:
              http://forums.offshoreelectrics.com/...161#post220161
              To the OP, I bet you could hit 50 with the x645. If not with the 2 Protec 4200's, at least with 6s2p
              www.keithbradleyboats.com
              • v-spec
                • Jun 2009
                • 1046
                That's not too bad then in my opinion I'm not sure what others shoot for though. Obviously the cooler the better esc wise. Batteries I think are fine and motor a little warm. Do you have 1 cooling line for both motor and esc? If not you could do a dual pickup. I'd imagine you have it that way though.
                • electric
                  • 1973
                  I am a little surprised on the top seed on the m445. I hit the 645 perfect. Really, I have over time discovered that the speed calculator that Steven has here on the tips forum is usually pretty accurate. It really is a great tool for estimating how fast a boat will go.
                  • dtacmed
                    • Mar 2008
                    • 215
                    One cooling line will most likely add a 2nd pickup.
                    • dtacmed
                      • Mar 2008
                      • 215
                      After 4 more runs today on a smooth lake the X445 running the 4200 45Cs or 5000 30Cs are consisently producing runs between 44-46 mph. Motor temp topped out at 140 after a 2 min wide open run. Batteries and ESC around the 105 range.
