Fuller's Mono Hardware Lube ?
  • dtacmed
    • Mar 2008
    • 215
    Any suggestions on Greasing the drive. Its the Square flex that slides in only from the motor side. So far I have to pull the motor just to grease the shaft. Any other way to do this. Not enough room or play to just loosen the collet and remove it.
    Thanks
  • electric
    • 1973
    I used to do that, but then I went to just pulling the stut off and coming out the back end. That way I could also take off the prop and grease the shaft that is in the strut.
    • electric
      • 1973
      The other solution, is to toss the square flex and buy a regular flex cable and the problem is solved for good!!
      • dtacmed
        • Mar 2008
        • 215
        Do I pull the prop shaft and just replace with regular flex and teflon. What size prop shaft do I need for x445. Currently the cable is 187. New to this level of boating any help is great.
        • dtacmed
          • Mar 2008
          • 215
          Thanks electric. Made sure bolts were epoxyed. Un screwed strut and bingo everything slides out nicely. Thanks again.
