what prop for a tenshock mini eco with a 4200kv motor ?
  • lucozader
    • 144
    ???what
  • TotalPackage
    • 622
    I would think a x427,x430,x432,x435 and 2s my friend tenshocks are good motors. There is 1427 also which is a 1.4 pitch like the x4 series but it has more lift incorporated in the blade style.The sweet one will likely be the 430!
    • v-spec
      • Jun 2009
      • 1046
      What flex do you have the threaded or ?
      • CornelP
        • 793
        For an Eco you need a submerged prop type, a bit different from the surface ones. Most eco props are around 26-32mm. For the size of yours, I would go with the 26-28. The only problem is finding these props: Graupner only makes 29 and 30. Hydro&Marine makes a 25 and a 28, but they do not come cheap:
        • TotalPackage
          • 622
          why do you NEED a submerged prop? Also if want the octura to be submerged just submerge it lol. Like i said octuras go down to 27 mm. I dont see much difference between a grapuner k and octura x series but anyway....
          • v-spec
            • Jun 2009
            • 1046
            It doesn't matter anyways cause a 27mm is going to be too big on that motor even more so with the prop being totally submerged.
            • CornelP
              • 793
              A submerged prop for the eco class has a different cupping and is a bit more rounded...
              • sailr
                • Nov 2007
                • 7128
                Because the boat has a submerged prop! It runs totally under water so it is under constant load...unlike a surface prop which is what most of us usually run. A submerged prop has to be much smaller.
                Mini Cat Racing USA
                www.minicatracingusa.com
                • sailr
                  • Nov 2007
                  • 7128
                  27mm diameter, 34mm pitch for 3200KV on 3S or 4200KV on 2S. These are for 4mm threaded shaft. Original TENSHOCK props.
                  If my camera wasn't dead I'd send you a pic of a prop IN THE PACKAGE.
                  Mini Cat Racing USA
                  • CornelP
                    • 793
                    Sailr is right, Tenshock only makes two diameters prop for the eco :27 for the mini (two options of pitch) and 29 for the eco expert (again different pitches).
                    • sailr
                      • Nov 2007
                      • 7128
                      The Graupner and Octura props have big wide blades on them. The Tenshock submerged props have a much narrower blade...more like a real racing prop on a full scale racing boat.
                      Tenshock Stainless Prop:
                      Carbon prop typical of Graupner and Octura:
                      Mini Cat Racing USA
